Home > Puma (Tdci) > Service recalls
Mynstral
United Kingdom 2015 Defender 110 Puma 2.2 USW Montalcino Red
Service recalls
Hi.
I'm new to the Puma and this forum.
I have a 2010 110 utility. Are there any recalls for this model year? How do I know if they have been fixed? it was 1 year old when purchased. Have they sorted the dodgy clutches and gearboxes from the early 07's? Is there any thing else i should get dealer to look at?
Thanks in advance, Myn.
Post #125953 22nd Feb 2012 7:40pm
Eduardo
Mynstral,
Welcome to the forum and to the Puma club.
Regarding your question the easy way to know if a recall is pending is to registered yourself in the www.landrovertechinfo.com known also as http://topix.landrover.jlrext.com (its free!)
After registered, with your VIN (SALLXXXXXXXXX) you can check if a recall is pending.
Regarding other issues a lecture of the forum post will be very good.
Cheers! Eduardo
Post #125986 22nd Feb 2012 9:11pm
Nick T
England 2010 Defender 90 Puma 2.4 HT Galway Green
Thanks for the post Eduardo-I too will benefit.
Thumbs Up
Post #126018 22nd Feb 2012 10:40pm
Mynstral
Thanks Eduardo.
Post #126025 22nd Feb 2012 10:54pm
I have MY2010 and so far...
1. transfer box rear oil seal
2. door closing jobbies (the metal door things that keep the doors open)
3. crankcase breather pipe heater (only for extreme cold climates)
that's about it ...
maybe check headlight bezels and any other rusty bits showing ....
Post #126031 22nd Feb 2012 11:07pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Rear Window Heater, if fitted, can have heating circuit damaged by high level brake light pod. Replacement has a modified heating grid. Symptoms of failure - top 3 heater elements fail.
I've also had the front door stay torsion bars replaced and the transfer box rear oil seal. 2010MY 90 XS. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #126038 22nd Feb 2012 11:21pm
nice one WelshGas - forgot about that one ...had mine done too Thumbs Up
Post #126040 22nd Feb 2012 11:23pm
Happyoldgit
What is the issue with the door stays? Steve.
http://forums.lr4x4.com
Post #126089 23rd Feb 2012 10:21am
WelshGas
Not exactly a recall but changed without any hassle. Front doors have a torsion spring type arrangement to click into place when they are at bout 75* open and keep them open. It releases when pulled shut, against the resistance of this torsion spring. Neither of mine would stay open. Hence changed under warranty. Thumbs Up LANDYWATCH
Post #126099 23rd Feb 2012 11:48am
nickhodgson
Are you very sure that the actual torsion bars were changed? On mine I just tightened the bolts and they started holding the doors as normal.
Nick
Post #126124 23rd Feb 2012 2:36pm
Happyoldgit
Ah got you. Mine were like that but cured it by tightening the bolts too. That said the drivers door stay has ripped through the door seal so I'll be asking for that to be replaced when it goes in for service next month. Steve.
Post #126139 23rd Feb 2012 3:33pm
WelshGas
I tightened them up at first - mentioned this at the 1st service and they changed them at the next visit when they did the transfer box seal. LANDYWATCH
Post #126272 23rd Feb 2012 10:50pm
