![]() | Home > Maintenance & Modifications > All-in-one Multimedia & GPS solution? |
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673
Yeah, I'm also thinking that's the way forward. Amp/sub will have to be on the back of the cubby box, it's a 90. Or else have the audio shop make an enclosure that fits between the safe and the cubby box? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
| farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299
Click image to enlarge 8" jl sub in the back of the cubbybox. my new set up has the amp in the cubbybox with the jl sub mounted ontop with a metal grille over it - i think the sould is better now. greeni - where did you mount your 6x9s? |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385
The rear of mine is awaiting a full custom drawer system, which will house the amp and sub.. as well.
The 6x9s are in the cubby and some cheap boxes in the back.. the sub has an amp attached, the first time Mrs Greeni saw the sub, she swore ! JBL's
Focals, the boxes are bolted to the tub in existing holes, that the seats used to be bolted to! QRZ 2e0vpf |
| T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101
youused dynamat on this at all. I'd like to insulate and quieten down the 110 ready for some tunes, Theres room for a sub under the rear seat of the 110 |
It sure is !!!!! Lots of it too, double layered on the wheel tubs ! QRZ 2e0vpf
good, worth every penny in these thngs, did you do doors and roof aswell? |
No, I've never really had time strip it all out, though it's a must...
My head unit is a Sony with an 'aux' in plug, the iphone plugs in and I use it as an Ipod, also phone calls come through the speakers and it works as an hands free...double bonus. As for reverse cameras, if I don't see it in my mirrors, I stop when I hit it ! QRZ 2e0vpf |
| iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343
That was my philosophy until I wrote off a Renault Clio, still only a broken reversing light on mine. |
Nice! Is that a 'slimeline' JBL sub? Do you have the model number please? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
The joys of Defender ownership...my green 90 had more hits than the Bee Gees, never damaged it ! QRZ 2e0vpf |
hi naks, its a bog standard 8" sub; i will look through my old invoices tonight to see if i can find a part number. the car audio specialists recommended NOT going for the slimline underseat option as they know that my taste is for full bass not just enhanced bass. i prefer the sub pointing upwards in my 110 and the grille is very robust (18 month old son walks on it!). |
After weeks of searching high and low, I finally settled on the Pioneer DVH-735av:
Click image to enlarge Decided to keep the GPS separate as there's nothing wrong with the Garmin unit I have now. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
What you will find oh your LHD so UR Ok
err, nope, we're RHD in South Africa 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
