Home > Maintenance & Modifications > Useful modifications while the dash is in bits
Page 2 of 2 <12
JWL
Put a permanent live socket in, can charge items without having to turn the key.
Post #123496 12th Feb 2012 7:21pm
Mountain_man
Wales
Mount a set of tweeters and bury the cross-overs in the void behind the dash.
Post #123515 12th Feb 2012 8:03pm
markb110
Hi Pete
Thanks for the comments.
I used a rubber blanking grommet to fill the hole from the original washer jet.
When i relocated the washer jets i kept the grommets that are already there (for the left hand drive wipers) and made a hole in the centre to pass through the inner part of the washer jet.
When getting a second washer jet make sure that you get the one with the longer tube fitting as there is a shorter one available and finally its a bit tight inside the dash to get the securing nut on - just be patient oh and put the plastic pipe ends into a mug of boiled water as this makes them easier to slide onto the fittings without risking any damage
Good luck
Mark
Post #123524 12th Feb 2012 8:16pm
kzycnn
United Kingdom 2003 Defender 110 Td5 XS CSW Oslo Blue
I've got the mudstuff side window demister kit. There was an article on it in LRM some time ago when they fitted to a 110. Does make an improvement. If you go for it, play about with the demister vent location with the dash partly assembled - there isn't a huge amount of room but you can improve on the location in the instructions.
How about heated mirrors? That's my next mod.
Tony
Post #123575 13th Feb 2012 8:26am
dgardel
Italy
PeteA wrote:
LandRoverAnorak wrote:
Swap the front wiper relay for the VW variable one.
Run a link wire to the rear wiper switch to provide auto wash wipe when used with the intermittent rear wiper kit.
Possibly LED instrument lights?
One of the things I remember doing years ago to a Series III was fitting a restrictor in the passenger side windscreen demister pipe to divert more airflow to the drivers' side. Less useful if you have a heated screen, of course.
Darren
Where is the wiper realy located, I suspect behind the instrument module that i have just replaced Embarassed not sure I understand your link wire mod but the led instruments are a good idea.
I've a heated screen so no need for the airlow mod
Pete
Here my "little doc" for the Mod....
https://files.me.com/daniele.gardellin/kd6401 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #123585 13th Feb 2012 10:04am
Retroanaconda
I fitted side-window demisters without paying Mudstuff £130 for the privilege. Just make your own. I did a little write-up here:
http://www.retroanaconda.com/landrover/201...demisters/
I've also done the double-washer jet mod. With the driver's one angled slightly to the off-side it works very well. Don't have to use anywhere near as much fluid as it actually reaches where the blades wipe.
I added a layer of soundproofing behind the dashboard as well.
Post #123945 14th Feb 2012 8:57pm
PeteA
Thanks to all for the suggestions, I fitted the VW wiper relay and the extra window washer, leaving the old one in the original place gives the drivers screen a double wash (sod the passenger!) Thumbs Up . Demisters will have to wait until next time.
Now its time to fit my heated mirrors and chequer plate rear seat bases.
Pete
Post #124924 18th Feb 2012 11:28am
Tiger
Post #228138 17th Apr 2013 2:14pm
I've got a .pdf document at home for the military side vents as fitted to the arctic vehicles.
They're small round (maybe an inch, or 1 1/4" diameter) vents that fit in either end of the dash (through the grab handle, and through the panel where the heater controls are) with some decent sized convoluted pipe that goes into a T piece for the windscreen vents.
I'll dig it out and post it up here.
Post #228164 17th Apr 2013 3:44pm
Litch
MK wrote:
Has the wiper motor enough power to spray through 2 screen washers? Or is at limits like everything else....
Yes it copes perfectly.
I did this very same conversion 14-years ago but much more recently I decided to replace the single-motor reservoir for a twin-motor one with each pump serving a twin nozzle (soft-top with no rear wash/wipe to worry about). The pressure & amount of water delivered through each nozzle has not changed however the increase in capacity is a definate improvement. ONE LIFE, GET IT!
Post #228688 18th Apr 2013 9:17pm
SiWhite
United Kingdom 2013 Defender 110 Puma 2.4 USW Stornoway Grey
Still not getting this Darren - can you explain it in words of one syllable for those of us lacking in wiring imagination Shocked My blog - www.anacreinhampshire.blogspot.co.uk
110 TD5 BuildHERE - sold!
110 Tdci Build HERE - sold!
Passat Alltrack - 4x4, auto, 45mpg, gloriously comfortable - but not a Defender!
Post #228711 18th Apr 2013 9:56pm
Hi Simon,
I changed the rear wiper relay for the kit shown below (bought from eBay):
If just installed on its' own, it makes the rear wiper work intermittently. However, by adding an extra wire from the spare terminal (green wire with blue spade connector) to the back of the rear washer switch, the wiper will run continuously when the washer switch is pressed.
I hope this helps. Darren
Post #228729 18th Apr 2013 10:31pm
SiWhite
Ah - got you now - thanks! My blog - www.anacreinhampshire.blogspot.co.uk
Post #228751 19th Apr 2013 6:18am
BigWheels
There is a washer fluid warmer thingy ypo can buy which is reputed to clean better, clear frost & remove oil, insect splatter & bird droppings with your wipers. It is pricey though. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
Post #229116 20th Apr 2013 3:01pm
smb
It is excellent though. You use a lot less washer fluid and its great in bad weather and on icey windscreens.
It's the one thing I will have in all future cars
Post #229117 20th Apr 2013 3:12pm
Page 2 of 2 <12
