Home > Maintenance & Modifications > Useful modifications while the dash is in bits |
PeteA Member Since: 14 Jan 2012 Location: Lancs Posts: 44 |
I had the pleasure today of replacing the windscreen wiper drives on my XS 90, 3 hours later and with the dash in a 1000 pieces i thought i 'd ask what are the best mods to do before I put it back together again. Ideas were;
Bigger Mud stuff demisters with side vents - are they any good, at £130 i think there a bit pricy http://www.mudstuff.co.uk/DefenderVENT.shtml Auxilary harness / switch for roof lights (no lights fitted yet) Rev counter instead of the clock Any other ideas or comments welcome soon as when its back in one piece I intend it to stay that way! Pete |
11th Feb 2012 5:23pm |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 |
Install a wiring loom & switch for a heated windscreen?
11th Feb 2012 9:55pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
LRM [or was it LRO] did a mini review of those demisters last month ... didnt rate them too highly
And for what are basically a pair of shaped plastic tubes .... £130 They are having a laugh Guns and Landrovers .... anything else is irrelevant. |
11th Feb 2012 10:13pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5460 |
I think you are thinking of a different product. The ones mud stuff do are very good, the ones in the mag where bits of plastic that fitted to the top of the dash for £80 ish. Andy |
11th Feb 2012 10:21pm |
These are the crappy ones
http://www.defenderdemister.com/ Andy |
11th Feb 2012 10:26pm |
I stand corrected ... apologies to mud Stuff Guns and Landrovers .... anything else is irrelevant. |
11th Feb 2012 10:30pm |
Thanks Andy I've seen these and I am not impressed, have you tried the Mudstuff ones? Its either fit those or try some homebrew ones. I think the double screen washers and wiring for heated screen are a good idea, thanks for the suggestions guys Pete |
11th Feb 2012 10:32pm |
Paullr90 Member Since: 06 Feb 2011 Location: Derby Posts: 93 |
[/quote]
Thanks Andy I've seen these and I am not impressed, have you tried the Mudstuff ones? Its either fit those or try some homebrew ones. Pete[/quote] No I have not tried them myself, but have seen them and like , having the heated screen makes a massive difference, but the side windows are a pain, just need to save enough pennies. Andy |
11th Feb 2012 10:43pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2293 |
Has the wiper motor enough power to spray through 2 screen washers? Or is at limits like everything else.... Puma 110" SW
12th Feb 2012 4:20pm |
Hi Mark I take it you used the existing two holes in the bulk head that are currently plugged ? What did you seal up the old nozzle hole with? PS like your motor, same year as mine but mines alot less modified Cheers Pete |
12th Feb 2012 4:37pm |
Swap the front wiper relay for the VW variable one.
Run a link wire to the rear wiper switch to provide auto wash wipe when used with the intermittent rear wiper kit. Possibly LED instrument lights? One of the things I remember doing years ago to a Series III was fitting a restrictor in the passenger side windscreen demister pipe to divert more airflow to the drivers' side. Less useful if you have a heated screen, of course. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
12th Feb 2012 4:45pm |
Darren Where is the wiper realy located, I suspect behind the instrument module that i have just replaced not sure I understand your link wire mod but the led instruments are a good idea. I've a heated screen so no need for the airlow mod Pete |
12th Feb 2012 4:51pm |
Yeah, the relay is behind the instruments. Take a look HERE for more details.
The link wire thing is part of the instructions if you buy the rear intermittent wiper kit that can be found on eBay. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
12th Feb 2012 5:32pm |
