Home > Maintenance & Modifications > Useful modifications while the dash is in bits
PeteA
I had the pleasure today of replacing the windscreen wiper drives on my XS 90, 3 hours later and with the dash in a 1000 pieces i thought i 'd ask what are the best mods to do before I put it back together again. Ideas were;
Bigger Mud stuff demisters with side vents - are they any good, at £130 i think there a bit pricy
http://www.mudstuff.co.uk/DefenderVENT.shtml
Auxilary harness / switch for roof lights (no lights fitted yet)
Rev counter instead of the clock
Any other ideas or comments welcome soon as when its back in one piece I intend it to stay that way!
Pete
Post #123262 11th Feb 2012 5:23pm
markb110
Hi Pete
Whilst i last had my dash apart i got some pipe and tee pieces from halfords and doubled up my screen washers
See pic
Good luck
Mark
Post #123299 11th Feb 2012 8:53pm
WarPig
Install a wiring loom & switch for a heated windscreen?
Post #123311 11th Feb 2012 9:55pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
LRM [or was it LRO] did a mini review of those demisters last month ... didnt rate them too highly Whistle
And for what are basically a pair of shaped plastic tubes .... £130 Shocked They are having a laugh Rolling with laughter Guns and Landrovers .... anything else is irrelevant.
Post #123316 11th Feb 2012 10:13pm
landy andy
I think you are thinking of a different product. The ones mud stuff do are very good, the ones in the mag where Censored bits of plastic that fitted to the top of the dash for £80 ish.
Andy
Post #123319 11th Feb 2012 10:21pm
landy andy
These are the crappy ones
http://www.defenderdemister.com/
Andy
Post #123321 11th Feb 2012 10:26pm
Dave-H
Andy
I stand corrected ... apologies to mud Stuff Embarassed Guns and Landrovers .... anything else is irrelevant.
Post #123322 11th Feb 2012 10:30pm
PeteA
Andy
Thanks Andy I've seen these and I am not impressed, have you tried the Mudstuff ones? Its either fit those or try some homebrew ones.
I think the double screen washers and wiring for heated screen are a good idea, thanks for the suggestions guys
Pete
Post #123324 11th Feb 2012 10:32pm
Paullr90
United Kingdom 2003 Defender 90 Td5 XS CSW Bonatti Grey
Another thumbs up to do the twin washers. Did mine when I was messing with the radio, makes a big difference. 2003 Td5 90XS
1970 Series 11A 2.25TD
2013 Freelander 2 HSE Lux (the wife's)
Post #123326 11th Feb 2012 10:32pm
landy andy
[/quote]
Pete[/quote]
No I have not tried them myself, but have seen them and like Thumbs Up , having the heated screen makes a massive difference, but the side windows are a pain, just need to save enough pennies.
Andy
Post #123327 11th Feb 2012 10:43pm
MK
Has the wiper motor enough power to spray through 2 screen washers? Or is at limits like everything else.... Puma 110" SW
Post #123427 12th Feb 2012 4:20pm
PeteA
markb110 wrote:
Hi Pete
See pic
Good luck
Mark
Hi Mark
I take it you used the existing two holes in the bulk head that are currently plugged ? What did you seal up the old nozzle hole with?
PS like your motor, same year as mine but mines alot less modified Bow down
Pete
Post #123429 12th Feb 2012 4:37pm
Swap the front wiper relay for the VW variable one.
Run a link wire to the rear wiper switch to provide auto wash wipe when used with the intermittent rear wiper kit.
Possibly LED instrument lights?
One of the things I remember doing years ago to a Series III was fitting a restrictor in the passenger side windscreen demister pipe to divert more airflow to the drivers' side. Less useful if you have a heated screen, of course. Darren
Post #123431 12th Feb 2012 4:45pm
PeteA
Darren
Where is the wiper realy located, I suspect behind the instrument module that i have just replaced Embarassed not sure I understand your link wire mod but the led instruments are a good idea.
I've a heated screen so no need for the airlow mod
Pete
Post #123432 12th Feb 2012 4:51pm
Yeah, the relay is behind the instruments. Take a look HERE for more details.
The link wire thing is part of the instructions if you buy the rear intermittent wiper kit that can be found on eBay. Darren
Post #123452 12th Feb 2012 5:32pm
