![]() | Home > Maintenance & Modifications > Soldering wiring together |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6725 ![]() ![]() ![]() |
You need electrical solder, and not separate flux. You don't melt the wires!
A heat gun will do the best job, but a carefully directed lighter will be fine ![]() ![]() ![]() |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 ![]() ![]() ![]() |
Best to "tin" the wires first, just melt some solder onto each piece, then put the two together and apply the soldering iron and they will be joined, as for shrink wrap, you can shrink it with the soldering iron.
Good info here http://www.teamnovak.com/tech_info/how_to/solder/index.html |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2038 ![]() ![]() |
I didn't actually mean melt the wires, you melt the solder onto the wires to hold them together, clearly! Sorry.
![]() Is it best to wrap the wires together first, then apply the solder? I have a blow torch, if used at an appropriate distance maybe that would work ![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Great Link, thanks so much
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Youtube is always worth a punt..
(it's where I learnt to cook.... ) QRZ M8VPF |
Don't know but this might help. How I connected the trigger for the spotlights.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21022 ![]() ![]() |
I would wrap the bare wire too at the same time add a bit of strength as just the solder only can be a touch weak especially on larger wiring cables
I have learnt a lot today, thanks guys, looks simple so going to do some practice work tonight on old bits of wire in the warmth of the house! 2016 D4 HSE
[quote="The Boy"]Don't know but this might help. How I connected the trigger for the spotlights.
![]() I would give that 10/10 for soldering skill :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
You may find these 'Tap connectors' useful: http://www.vehicle-wiring-products.eu/VWP-...rs.php#tap
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 ![]() |
Then again you'll regret it as they will cause more problems. Stear clear, also more commonly called 'Scotchlock'. |
I thought the tap connectors were different though? I thought the 'scotchlock' type was at the top of the page. Maybe wrong |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 ![]() ![]() ![]() |
tap, connectors
