Home > Maintenance & Modifications > Soldering wiring together
RRUK
Is this as simple as using a simple pointed soldering stick, some solder flux and just melting the 2 wires together ? (after stripping back insulation of course)
This is what I have in the garage, would like to actually use it one day Whistle
Any joins need heat shrink tubing yes? And I think that requires a heat gun. Something else to buy Big Cry 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #122091 7th Feb 2012 4:53pm
Martin
Site Admin
You need electrical solder, and not separate flux. You don't melt the wires!
A heat gun will do the best job, but a carefully directed lighter will be fine Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #122092 7th Feb 2012 4:56pm
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Best to "tin" the wires first, just melt some solder onto each piece, then put the two together and apply the soldering iron and they will be joined, as for shrink wrap, you can shrink it with the soldering iron.
Good info here http://www.teamnovak.com/tech_info/how_to/solder/index.html
Post #122094 7th Feb 2012 4:58pm
RRUK
I didn't actually mean melt the wires, you melt the solder onto the wires to hold them together, clearly! Sorry. Embarassed
Is it best to wrap the wires together first, then apply the solder?
I have a blow torch, if used at an appropriate distance maybe that would work Very Happy 2016 D4 HSE
Post #122095 7th Feb 2012 5:00pm
RRUK
Great Link, thanks so much Thumbs Up 2016 D4 HSE
Post #122096 7th Feb 2012 5:05pm
Youtube is always worth a punt..
(it's where I learnt to cook.... ) QRZ 2e0vpf
Post #122099 7th Feb 2012 5:17pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Don't know but this might help. How I connected the trigger for the spotlights.
Post #122112 7th Feb 2012 6:22pm
I would wrap the bare wire too at the same time add a bit of strength as just the solder only can be a touch weak especially on larger wiring cables
Post #122113 7th Feb 2012 6:23pm
RRUK
I have learnt a lot today, thanks guys, looks simple so going to do some practice work tonight on old bits of wire in the warmth of the house! 2016 D4 HSE
Post #122118 7th Feb 2012 6:36pm
[quote="The Boy"]Don't know but this might help. How I connected the trigger for the spotlights.
I would give that 10/10 for soldering skill :thumbsup:
Post #122129 7th Feb 2012 7:09pm
You may find these 'Tap connectors' useful: http://www.vehicle-wiring-products.eu/VWP-...rs.php#tap
Post #122132 7th Feb 2012 7:12pm
Romadog
Then again you'll regret it as they will cause more problems. Stear clear, also more commonly called 'Scotchlock'.
Post #122144 7th Feb 2012 7:32pm
I thought the tap connectors were different though? I thought the 'scotchlock' type was at the top of the page. Maybe wrong
Post #122147 7th Feb 2012 7:35pm
kingofthesparks
Location: Very close to Watford gap services , northants
United Kingdom 2012 Defender 90 Puma 2.2 HT Fuji White
tap, connectors Thumbs Up Thumbs Up Thumbs Up Thumbs Up
Post #122148 7th Feb 2012 7:38pm
Embarassed
Post #122150 7th Feb 2012 7:41pm
