![]() | Home > Maintenance & Modifications > Extreme4x4 progressive coil springs |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
i am 99% sure that extreme 4x4 are scorpian racing just different name so with the reputation scorpian had i wouldnt bother
Dan A Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 61 ![]() ![]() ![]() |
I'v used extreme 4x4 a couple of times now with no hastle.
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5971 ![]() ![]() |
Agreed, and from my experience Scorpion, they make a lot of "claims" about there kit. |
Well I haven't bought anything from them when they were any name but I went speak to them at billing in 2007 and made my mind up that they were a bunch of *$#€.
There gear may be good but the staff weren't then ![]() 2011MY 110 XS USW Black |
yer scorpian was a local one for us wernt it andy
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 ![]() |
Thanks for the feedback lads,
I'll give them a skip so. |
Look here:
http://www.defender2.net/forum/topic584.html?highlight=scorpion If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
I wouldn't touch Extreme 4x4 with a barge pole. There are many other better companies to buy from. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
Same here found them very good ![]() |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2670 ![]() ![]() ![]() |
Durite own Extreme 4x4 and have done since the original owner of Scorpion Racing went into liquidation.
I have used with no issues. I tend not to be loyal to anyone company as even the bigger companies that advertise in the magazines can fail to call you back and as so many business's offer the same or very similar products I just go elsewhere. Keith Gotts are fairly close to me as are Challenger 4x4 so when I have the time I support the local guys plus if they know you they are more likely to help you when you need them. Mark Ps going back to your original question, yes I had the progressive springs on my last 110. They are a very good spring. Just have in your mind exactly how you drive and the loads you are likley to carry and they will match the springs to your needs. Ask too if they will swap if you feel they are not quite right. Scorpion did that for me as well as swapping a shock absorber when I snapped the head off one during one of their novice winch challenge events I used to take part in. |
johnszs Member Since: 16 Aug 2010 Location: Hereford Posts: 459 ![]() ![]() ![]() |
I have used extreme and had no problems wirh roz or colin, but i was parting with money , which helps with attitudes 2004 TD5 Defender 90 xs station wagon
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 ![]() ![]() |
Both my TD5 and now the Puma run on scorpion heavy duty back springs and anti roll bar never had any issues, will be looking for the same again for the new one soon. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Had a set on my last TD5 ... took them off, made it worse! Guns and Landrovers .... anything else is irrelevant.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8321 ![]() ![]() ![]() |
arent std 110 CSW/USW progressive springs? Cheers
