![]() | Home > Technical > Recharging dual batteries? |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
As BPMan wrote
So the nat luna battery monitor joins the batteries as the main one has full voltage (more than 13.somethingV) If i remember correctly you can set the trigger voltage on this system but then you have to open it up, void your warrantee and find the right resistor. Too long ago to remember how it looked inside. Its a typical problem with this unit (set for classic batteries) and the higher voltage of AGM batteries, i had the same issue with my discovery and dual optima's before. Can leave you with 2 half batteries after connecting the c-tek. Well, should be sorted after about 60 hours of charging as then both will be full again. Would recommend you to put a manual switch between the batteries so you can isolate them when charging. 2cents ![]() |
Paul - the national luma battery management system is doing what it is supposed to do, it will manage the charging of the batteries for you. To be honest, why not run the truck for a few weeks, keeping an eye on the NL display showing the state of the batteries? These battery management systems are very good, currently other forum members are in extreme cold temperatures in the arctic circle running the same system as you and as far as we can tell they are fine. whoever owned your truck before you knew what they were doing. most of us just have a single battery and run fine. enjoy your truck! bp |
bolampau Member Since: 06 Jan 2012 Location: Lincolnshire Posts: 100 ![]() ![]() ![]() |
Thanks BPMan, the charger has now finished, it took 7 hours roughly. After disconnecting the Ctek, the dual monitor shows both batteries as above the normal mark now - it's too dark to read the exact voltage. The car started up straight away and all seems well. I think I'm gonna fit the Ctek standard lead to the main battery and trail the connector outside the seat box. Then I won't have to lift the seat base to do a recharge in future! Cheers, Paul |
Apologies, as I didn't thank Tetra805 for his advice! |
my 110 has not been started since before december, but I bet it will be fine tomorrow morning (with a single battery)
it's been on the ctek since last saturday ![]() |
SHOCK!!!! HORROR!!!! "Hold the front page!" Steve you're not!! You can't!! What will the neighbours say? The 110s not being dug out surely? Don't believe it, refuse to look and see if there's an answer! Someone else is bound to start a new thread if you do! ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
are you taking the p!55 Mal ? |
![]() ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Well BP Ice has experienced some light Yorkshire snow today. Ice looks cool
![]() Brendan |
He didn't get lost then ![]() 2011MY 110 XS USW Black |
Well let's just say he made it ok, although it was an interesting route he took. He did manage to explore one of our local green lanes on his way, so not exactly the fastest route. He did mention something about his sat nav. Brendan |
WHAT! He popped the ICE's cherry ![]() 2011MY 110 XS USW Black |
i've been off roading in the ice in france ![]() |
all back now, ice ready to be de-tented tomorrow.. great minds are thinking about how to do this
snowed all the way from Brendan's to home ... no hold ups except for sh!troen drivers as usual. just going to sort out the pics ... |
