![]() | Home > Technical > Recharging dual batteries? |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253
Is the split charge not all connected? if so why do you need to disconnect the batteries? Just drive it and they'll charge?
| Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2684
Paul, I have a Ctek and I recharge both my batteries by plugging the charger into one of the hella plugs I have in the back of the landy. The only precaution is that when you do this, you must never switch on the ignition. As for the main/cranking battery, I had the auto electrician put a 12V cigarette lighter under the passenger seat that plugs directly into the battery itself. To charge the battery, I just plug the Ctek in the plug, no need to remove seats, attach clips to batteries, etc. When camping it makes is easy to just charge batteries: unroll power cord extension, plug Ctek in extension plug and rear/front battery. By the time I'm done, SWAMBO has very graciously opened an ice-cold beer for me 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
Paul,
just to be clear, do you have a 12v socket in the rear next to the speakers ? If not, you can remove the trim and you will find a purple and black wire, these are permanent 12v fused, install a 12v socket and you can charge from there. i'm guessing you don't use the truck often ? that's why you need to trickle charge ? otherwise, like Mike says, the management system will look after the batteries. nice spec truck coming complete with all that gear |
I disagree. IME, even if you drive the truck everyday, you will never recharge both batteries completely, especially during winter. Every 2-3 months you should always plug your Ctek into the batteries to top them up. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
| bolampau Member Since: 06 Jan 2012 Location: Lincolnshire Posts: 100
Hi BigMike, Yep, the split charge is working well. But with the cold weather I thought it'd be a good idea to recharge batteries occasionally. Also, I'll leave the fridge/freezer on 24/7 when we're travelling so assumed the auxilliary battery would be depleted and benefit from a charge at end of journey. Thanks, Paul |
Thanks for this, I'm gonna check to see if there's a socket this afternoon. Cheers, Paul |
Thanks Naks, so if I connect a Ctek standard attachment lead to each battery I can charge each one separately, without having to remove the seats? Just trail the two leads outside the passenger seat. There was one lead that came with the charger so I'd only have to buy a second lead for the other battery - less than £10! Sounds like a good plan to me! Cheers, Paul |
my ctek came with a 12v socket-plug, a battery and croc clips. I use the 12v plug. if the ctek pushes more than 13.8v, then the battery management system should control the charging of both batteries - because the VSR will join them |
Thanks BPMan, Just so I get my head round this, the 12v socket plug would only work if connected to a permanently live cigar socket? Unfortunately, I only have the ARB fridge lead that is permanently live - the three cigar sockets are dead once the ignition is off. That's the reason why I want to connect a standard Ctek lead to each battery and trail them to the outside of the seat ....I can then plug the charger in one at a time. Is this reasonable, as removing the batteries is a PITA! Please correct me if I'm wrong! Cheers, Paul |
hi Paul,
if you don't have a 12v socket in the rear next to the speaker, take the panel off (the right hand side looking from the back of the vehicle / offside). Behind the panel there was purple and black wires (2 off), these are permanent lives (ignition on/off/locked/unlocked) they are live. pop a 12v socket on the panel and wire it up, then use the ctek charger in thru the back door. the next bit is based on the assumption your split charge system has a voltage sensing switch (or voltage sensing relay vsr), if you plug your ctek into the "new" live socket, the battery management system will sense a voltage of 13.8v and it will automatically manage the charging of the twin odysseys as if it was running. so you should not need to remove the batteries - thus saving the PITA |
Fantastic! I've got the idea now! I will try to fit a new 12v socket as you suggest. Won't do it tomorrow as it's curry night tonight and I'll sup a few pints of Abbot ale! Thanks for your help, Paul |
must be a land rover thing, I'm here with a glass of abbot ale
Personally I do not want to be charging both batteries at the same time through my dual battery solenoid/VSR/etc.
I prefer to play it safe, so before we set off for a camping trip, I charge each battery for a full 12 hours, separately. Once on the road, as soon as we get to camp, I plug the fridge and the deep-cycle battery into the campsite power (240V). This gives the deep-cycle battery a rest and charges it. The following day, with the fridge still running off 240V, I charge the main battery. After 2 days at a campsite, both batteries are fully charged, and I also have one fully charged battery on any given day. Obviously this won't work if your fridge does not do dual 12V/240V. In that case, just leave your fridge running off the deep-cycle while it charges, over 12hours it should be almost fully charged. Mind you, our camping trips are anything between 1 -3 weeks 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
Dunno hey, I'm sipping some Chivas 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged
