Home > Technical > How good is your heating?
Page 3 of 4 <1234>
mick
Think my in car temp gauge is fooked it said -40 this am Shocked Then warmed up to -32 Shocked Shocked
Post #121065 3rd Feb 2012 9:41pm
67_6Cyl
France
ZeDefender wrote:
Sounds just like here in Munich - same latitude?
Not quite. We're in the corner between France, Luxembourg, and Germany.
The French seem quite incapable of forecasting the temperature, we're offen 3 or 4 degrees below forcast.
Jon
Post #121072 3rd Feb 2012 9:48pm
PeteA
john adam wrote:
-8C this morning here in Paris and heating worked correctly after 15 minute (radiator muff completely closed), that is just 1 minute before arriving at work Crying or Very sad .
Carlo
PS I was in Santiago a couple of weeks ago: perfect weather Smile
Carlo I take it the radiator muff is the external type that you strap on ( a couple of potential double entendres available there), do they make any difference.
Pete
Post #121110 4th Feb 2012 12:05am
Landyrob
United Kingdom 2012 Defender 110 Puma 2.2 HT Alpine White
-14 here Big Cry left for work took 4 min too heat up after 15 min get's too hot on full heat.
but will get the webasto heating in the new 110 hardtop that i should collect next week. LANDROVER Defender Best 4 x 4 x Far
Defender TD4 90 Hardtop 2.4
Defender TD4 110 Hardtop 2.2
Post #121116 4th Feb 2012 1:07am
ZeDefender
I wonder if the heating in the left hand drive models doesn't work as well?
It seems as though all the "continentals" have a similar problem.
Mine never gets too hot (mostly not hot enough).
Matt
p.s. minus 18 again... Tell someone you love them today because life is short.
Post #121129 4th Feb 2012 7:49am
pom
thank god for the webasto and remote control to turn it on while in bed!
Pom
Post #121130 4th Feb 2012 7:50am
67_6Cyl
France
Matt
I don't think so. I get the full thermonuclear blast after 10 minutes or. It helps to have the ventilation off, or on 1 for the first few minutes, or it takes noticably longer to get warm.
When it is so cold, I've noticed that the thermostat is even less linear in its regulation than normal. Turning the heating down one notch you can go from toasty to frosty very quickly.
Haven't been out to look at the thermometer yet, and I don't really want to as it looks just too cold outside, probably somewhere around the -11 or -12.
Jon
Post #121132 4th Feb 2012 8:20am
alfajock
United Kingdom 1989 Defender 110 V8 Petrol CSW Bonatti Grey
My V8 warms up beautifully since the rebuild with a new rad and heater matrix which are not clogged up with mud. (Certainly much faster to get up to temp than my uber efficient daily driver C-class.)
But then the icicles from the roof leaks thaw out and the resultant deluge cools me down again Fully Restored 89 110 CSW V8
CLS 350 CDI for the sensible stuff
Post #121133 4th Feb 2012 8:24am
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
Mine is also lhd. and gets warm after 8-10 km - after 20 it gets unpleasantly warm....but I also have the problem that there is nothing between toast or frost.....found that opening the window a bit helps........ Whistle rather that than the heat in my 88"
Regards
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #121134 4th Feb 2012 8:28am
ZeDefender
Thanks - looks like another thing I need to question at the upcoming first service Rolling Eyes
Actually - I wonder if the snow cowl is restricting air flow Confused Tell someone you love them today because life is short.
Post #121135 4th Feb 2012 8:34am
dgardel
Italy
Pom
Thumbs Up Thumbs Up Thumbs Up Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #121136 4th Feb 2012 8:41am
ZeDefender
Pom
OKay, Show-Offs Laughing
Can any of you give me some rough ideas what one might set me back, including fitting (just some clues?)
Matt Tell someone you love them today because life is short.
Post #121138 4th Feb 2012 8:52am
ZeDefender
dgardel wrote:
Pom
Currently downloading your manual etc. Thumbs Up Tell someone you love them today because life is short.
Post #121145 4th Feb 2012 9:23am
Zagato
Anyone know why with one clicks difference on the heater knob you go from volcanic heat to ice cap freezing with no adjustment in between. I suppose that one "click" just shuts the heat vent off Rolling Eyes Wonder if anyone has improved the mechanism!?
Also if you switch the air-con off on mine and turn the heat right up nothing comes out unless you put the fan on Rolling Eyes (air-con has fan on all the time of course!) You godda love em Wink
Post #121146 4th Feb 2012 9:28am
ZeDefender
Same here - even with my pathetic heating, the heat-control is either on or off Rolling Eyes
I find windows work well when it's on...
I figure with my "no more Defender-spending" ban in place, auxiliary heating would have to wait until next year anyway. I've got my greenhouse heater in there and it's managed to raise the temperature to a toasty -7C at the front Thumbs Up
Off to walk the dog now, if I can drag her from the warmth... Tell someone you love them today because life is short.
Post #121152 4th Feb 2012 9:45am
Page 3 of 4 <1234>
