Home > Technical > How good is your heating? |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Think my in car temp gauge is fooked it said -40 this am Then warmed up to -32
3rd Feb 2012 9:41pm |
67_6Cyl Member Since: 10 Feb 2010 Location: France Posts: 97 |
Not quite. We're in the corner between France, Luxembourg, and Germany. The French seem quite incapable of forecasting the temperature, we're offen 3 or 4 degrees below forcast. Jon |
3rd Feb 2012 9:48pm |
Landyrob Member Since: 07 Jul 2011 Location: Switzerland Posts: 93 |
-14 here left for work took 4 min too heat up after 15 min get's too hot on full heat.
but will get the webasto heating in the new 110 hardtop that i should collect next week. LANDROVER Defender Best 4 x 4 x Far Defender TD4 90 Hardtop 2.4 Defender TD4 110 Hardtop 2.2 |
4th Feb 2012 1:07am |
I wonder if the heating in the left hand drive models doesn't work as well?
It seems as though all the "continentals" have a similar problem. Mine never gets too hot (mostly not hot enough). Matt p.s. minus 18 again... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
4th Feb 2012 7:49am |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 |
thank god for the webasto and remote control to turn it on while in bed!
Pom |
4th Feb 2012 7:50am |
I don't think so. I get the full thermonuclear blast after 10 minutes or. It helps to have the ventilation off, or on 1 for the first few minutes, or it takes noticably longer to get warm. When it is so cold, I've noticed that the thermostat is even less linear in its regulation than normal. Turning the heating down one notch you can go from toasty to frosty very quickly. Haven't been out to look at the thermometer yet, and I don't really want to as it looks just too cold outside, probably somewhere around the -11 or -12. Jon |
4th Feb 2012 8:20am |
alfajock Member Since: 12 Jan 2011 Location: Bedfordshire Posts: 227 |
My V8 warms up beautifully since the rebuild with a new rad and heater matrix which are not clogged up with mud. (Certainly much faster to get up to temp than my uber efficient daily driver C-class.)
But then the icicles from the roof leaks thaw out and the resultant deluge cools me down again Fully Restored 89 110 CSW V8 CLS 350 CDI for the sensible stuff |
4th Feb 2012 8:24am |
CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253 |
Mine is also lhd. and gets warm after 8-10 km - after 20 it gets unpleasantly warm....but I also have the problem that there is nothing between toast or frost.....found that opening the window a bit helps........ rather that than the heat in my 88"
Regards CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
4th Feb 2012 8:28am |
Thanks - looks like another thing I need to question at the upcoming first service
Actually - I wonder if the snow cowl is restricting air flow Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
4th Feb 2012 8:34am |
Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
4th Feb 2012 8:41am |
OKay, Show-Offs Can any of you give me some rough ideas what one might set me back, including fitting (just some clues?) Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
4th Feb 2012 8:52am |
Currently downloading your manual etc. Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
4th Feb 2012 9:23am |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 4992 |
Anyone know why with one clicks difference on the heater knob you go from volcanic heat to ice cap freezing with no adjustment in between. I suppose that one "click" just shuts the heat vent off Wonder if anyone has improved the mechanism!?
Also if you switch the air-con off on mine and turn the heat right up nothing comes out unless you put the fan on (air-con has fan on all the time of course!) You godda love em |
4th Feb 2012 9:28am |
Same here - even with my pathetic heating, the heat-control is either on or off
I find windows work well when it's on... I figure with my "no more Defender-spending" ban in place, auxiliary heating would have to wait until next year anyway. I've got my greenhouse heater in there and it's managed to raise the temperature to a toasty -7C at the front Off to walk the dog now, if I can drag her from the warmth... Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
4th Feb 2012 9:45am |
