Home > Technical > Odd noise, any ideas? |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
Sounds suspiciously like the same noise I had a month or two back.... turned out to be a knackered off side abs sensor...
Here's my tale ..... http://www.defender2.net/forum/topic10240.html Added on edit : If it is that, then the sensor ain't cheap..... £200'ish sticks in my mind.....although I try to blank it out.... Jon - 110 td5 [sold]. Currently Defenderless. Last edited by party monkey on 1st Feb 2012 7:02pm. Edited 1 time in total |
1st Feb 2012 6:59pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Try your UJs, go underneath just after a drive and check for a hot one.
Also check them for free play (wheels chocked and handbrake off) |
1st Feb 2012 7:01pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 16883 |
Aha, that's one thing I can rule out - I don't have ABS! However, looking at your thread it does appear to be a very similar noise. Interesting! |
1st Feb 2012 7:08pm |
Harryb450 Member Since: 11 Dec 2011 Location: over yonder Posts: 283 |
you've got the same symptoms that i had.................after a bit of fiddling i found it to be the front D/S wheel bearing |
1st Feb 2012 7:43pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5423 |
Rust on brake discs or hand brake drum as they have salted the roads due to cold weather?
Does touching the brakes alter the noise? Andy |
1st Feb 2012 10:19pm |
Could also be a siezed brake cylinder causing the pad to 'rattle'.
Sounds just like a CV joint breaking up. Guess how I know |
1st Feb 2012 10:34pm |
