Home > Td5 > Noise+TC light when cold and left lock applied |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 |
Wheel bearing on the way out?
16th Dec 2011 8:33am |
Check the TC/ABS wiring loom for chafing and/or damage. It sounds to be as though you possibly have a short circuit. I had similar on the rear a couple of years ago and it was just that, predominantly in damp conditions but disappeared when the loom dried out! Good luck with reaching a quick resolution.
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
16th Dec 2011 11:09am |
ben_j85jty Member Since: 03 Sep 2008 Location: Bicester, Oxfordshire Posts: 491 |
I would concur with both of the above...
When breaking do you find you press the pedal further the first time than the second? 2002 Defender 110 DC |
16th Dec 2011 2:03pm |
party monkey Member Since: 31 Dec 2010 Location: Oxon. Posts: 1311 |
No excessive brake pedal travel on first press that I've noticed. I've provisionally scheduled a quick check over at my local indy for early next week and will get them to check the bearing too, just to be on the safe side.
Near side front wheel bearing was replaced earlier this year following some spectacular metallic grinding noises one morning. I'll be able to have a decent mooch around over the weekend but the noise I'm getting is more consistent with chaffing/rubbing and along with the TC light initially when cold, makes me thinks K9F has a good point. Thanks all again..... Will report back Jon - 110 td5 [sold]. Currently Defenderless. |
16th Dec 2011 6:45pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
wheel bearing or diff. check the bearing yourself by jacking it up and seeing if you can waggle it top/bottom.
my vote is diff. |
16th Dec 2011 7:04pm |
From what you describe I would think the wheel bearing is causing the issue by inducing a larger air gap in the wheel speed sensor causing the TC/ABS to operate. As K9F states, you can also check the abs harness for signs of damage, or plug in a diagnostic tool capable of showing live data of the voltages at the wheel speed sensor to show any discrepancies from the normal 2.1-2.3 volts through the movement of the wheel, until you get the TC/ABS light. The wheel bearing is easy to check as Mike has already stated, if there is no play with the bearing then the harness/sensor is the most likely culprit.
Brian. |
16th Dec 2011 9:58pm |
Nanocom will be able to check if its the sensor. I have one if you want to give it a go 2002 Defender 110 DC
17th Dec 2011 12:53am |
Thanks all again for the suggestions.... I will check for wheel bearing play tomorrow. I checked that about 2 weeks ago ahead of the MOT last week but I do appreciate that the bearings can go from being fine one minute to knackered the next with precious little warning.
Ben - might take you up on the Nanocom offer (have another possible issue too).... we could sort out that Cadets stuff at the same time How you fixed Sunday ? Jon - 110 td5 [sold]. Currently Defenderless. |
17th Dec 2011 1:52am |
Quick update.
No play noted on wheel. No untoward noises on rotation either. Will have some more time tomorrow to have a proper mooch about. Jon - 110 td5 [sold]. Currently Defenderless. |
17th Dec 2011 11:28am |
Popped over to see Ben_j85jty today to take up his very kind offer of a quick 'nanocom'ing
Upshot is that the the 'Left' (Nanocom's terms) ABS/TC sensor is playing up. I had managed to squeeze her in at my local indy for an hour or two max of investigations ahead of crimbo, Armed with today's info, I can give them a darn good steer (no pun intended) as to where the problem lies. With thanks to Ben for his help today and also to all those who posted on this thread Jon - 110 td5 [sold]. Currently Defenderless. |
18th Dec 2011 8:53pm |
You're more than welcome! 2002 Defender 110 DC
18th Dec 2011 9:53pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 7709 |
just order up and change the sensor yourself if its shown as a faulty on nanocom
that accounts for the light on the dash what about the groan. when the last bearing failed, if it broke up maybe some swarf has contaminated the kingpin bearings? BigMike - on the front movement top to bottom could indicate wheel bearing and/or kingpin bearing wear movement left to right will only show wheel bearing wear. Cheers James 110 XS Utility 130 Puma Station wagon/camper (in the making) 90 Puma Hardtop |
19th Dec 2011 4:04pm |
Jon, you say that the left wheel sensor is playing up, in what way? Is it a higher voltage or no voltage at all? It could just be the air gap needs adjusted very slightly as the expansion of parts when warm could bring it back in line. Let me know the readings you got by pm if you would be so kind.
Brian. |
19th Dec 2011 5:22pm |
It was comming up with 2 errors,
First was out of ranged, logged 255 ( the maximum that can be recorded ) and intermittent comms 255 times. There were the same errors I had when I broke the sensor doing a swivel rebuild. My guess is knackered sensor/loom. Part Monkey is sending it to the local LR independent for ease and speed a it's his daily drive..... I am sure he will be along soon to say much the same! 2002 Defender 110 DC |
19th Dec 2011 6:23pm |
