Home > Wheels & Tyres > Are my tyres faulty |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Tyre Pressures LANDYWATCH
Neighbourhood Watch for Land Rover Owners http://www.landywatch.co.uk/smf2/index.php |
1st Feb 2012 8:41pm |
ginjez Member Since: 18 Sep 2011 Location: huddersfield Posts: 1751 |
Tyre pressures are correct. Anybody else running on these tyres?
1st Feb 2012 8:45pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 19602 |
I've always used 32 front 38 rear (Psi) As the hand book suggests. |
Not running the same tyre's as you myself. Are there many round abouts in your area? |
1st Feb 2012 8:46pm |
Just hills here but don't know what happened in her previous life. Certainly no sign of damage underneath.
1st Feb 2012 9:20pm |
It could have been taking corners and or going around round abouts a bit to fast. Or maybe contributed anyway. Not saying you have but maybe previous owner.
1st Feb 2012 9:25pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Got Cooper ST's on mine [265/75x16]
No issues at all, tread wear is perfectly even .. wearing well tbh, lost 2mm of depth in 17,000 miles I run mine 30 fr, 40 rr Guns and Landrovers .... anything else is irrelevant. |
1st Feb 2012 9:29pm |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
What pressures are you running? 130's have feeling's as well you know |
32 front, 38 rear with no weight in the tub.
1st Feb 2012 10:21pm |
Are they balanced properly?
1st Feb 2012 10:25pm |
Thanks kona for all the suggestions Steering wheel totally free of shakes at all speeds
1st Feb 2012 10:29pm |
No problem at all All I can think of If everything else is checked and is not a problem is that maybe it's a characteristic of your particular tyres. Especially if like you say the pressures are correct. Perhaps the previous owner was a bit of an over zealous driver cornering to quickly to often Failing all this just go for some KM2's like mine
1st Feb 2012 10:38pm |
Bfg's are my preferred tyre. Always had new Defenders in the past and had the sausage GG TR's exchanged for AT's before collection. Are the MT's noisy on road and what size do you run on. Fancied the 255's as a compromise between 235 and 265
1st Feb 2012 10:46pm |
I don't notice any noise difference to be honest nothing to take any notice of anyway! The Grabbers I had lasted very well and weren't actually wore out just wanted KM2's I bought the 235 the same as OEM because this was cheaper and I wanted a set of 5. Plus the fitting and balancing added too all in all must have cost about £800 - £900 Another thing is I would have thought fuel consumtion would have gone up a little with a wider tyre too. IMO all round a far superior tyre to the Grabber's in all manner of conditions. On reflection I wish I had chosen slightly wider even if just for looks
1st Feb 2012 10:56pm |
