Home > Puma (Tdci) > Newbie:- essential upgrades
Page 4 of 5 <12345>
CityDriver
United Kingdom 2012 Defender 110 Puma 2.2 USW Orkney Grey
farmer giles wrote:
ffs don't put anything chrome on your land rover unless you are a pikey and your wife does palm readings Wink
Check. I was not planning on anything even remotely bling. I like black stuff on a grey car, that's about as fancy as it gets.
Post #93137 7th Oct 2011 2:57pm
farmer giles
good man.
unlike every one else on here i will save money on waxoiling and go direct to a re-chassis with a galvanizing in 10 years. I still haven't washed my 110 since i bought it new from the dealer in december - 8000 miles ago Whistle
the only things that i find "essential" on a new land rover are wing top protectors - because i'm a sort arse and i climb on the vehicle to clean the screen; and a big boom boom stereo - sub,amp better mids and tweeters and ipod headunit - any sound deadening would only benifit my neighbours Cool
Post #93141 7th Oct 2011 3:14pm
Birdy
France 2011 Defender 110 Puma 2.4 XS CSW Santorini Black
I can see where Farmer Giles is coming from - I�m not sure myself about the economics of rustproofing/Waxoyling.
I�ve just replaced my 10-year-old TD5 with a brand-new 2.4 Puma (jury�s out as to how much of an improvement - if any); yes, the rear chassis member was a bit tatty and would have needed a bit of welded reinforcement around the tow bar to pass the MoT. And yes, in a couple of years time a new galvanised chassis would have been needed (but then the vehicle would have been good for at least another ten years).
But if I�d had it rustproofed from new, would it have made the slightest bit of difference? I think not.
I don�t have the facilities to do much work on my vehicles and considered having a company rust-proof my new Land Rover but, having seen the cost and gone through some T & Cs (�we�ll make a mess of your car but if you want us not to, then we�ll charge you even more�), I�ll do a Farmer Giles and save my money, with interest it�ll more than cover any welding needed years on down the line� I�ll probably get some spray-on goo to protect behind the headlamps and the rear chassis member, and that�s about it.
Peter
Post edited by admin team to comply with site rules
Post #93148 7th Oct 2011 4:08pm
CityDriver
I just want to prevent any early issues. No doubt thinks will rust eventually somewhere, but it's a limited effort for postponing issues in my mind. Plus I like a neat car, but that's just me.
Post #93156 7th Oct 2011 5:32pm
Zagato
Zagato, can you specify this a bit better? Do you mean getting all windows resealed just because the standard sealing is so poor?
CityDriver they are not sealed in the first place. You can do it yourself but it's a tricky/messy job far better to pay around �70 - �100 to get a window fitter to do it Thumbs Up
It's detailed in the water ingress manual (which I will try and find the link to again) along with where to seal your cappings etc Thumbs Up
Interesting view on not undersealing etc your car and I suppose there is a case for that when some pay �700+ for it to be done Shocked every 4-5 years but of course it's not just the chassis it's the doors that can corrode from the outset, seen the price of new ones Shocked not great in 5-10 years time or even longer and getting the spray work all done which will never match either Shocked rear tub spreaders, electrics, steps, bumpers, hinges, etc etc the list is long Rolling Eyes No matter if you are going to chop it in in 4-5 years time but it saves a lot of time and hassle by treating it all thoroughly from the outside and giving it a squirt every now and then there after. Imagining yourself sitting in a DC100 in the future should make you leap up off your bum and get some underseal Laughing
I have worked on a few farms and everyone used to look after their machinery, we had to scrape the rust off each year and slap on the old red oxide paint - similarly the Defender deserves looking after and have you seen the price of a new chassis Shocked let alone the agro of having to swap it over. Those chassis fastener points will be a pig to get off in 10+ years time. Let your door pillars rot at the bottom and around the top hinge etc and really your looking at bulkhead out eventually to re weld new bits in and then it will need doing again not so far down the line...once rot has got in it's a constant battle to keep cutting it out and welding in new bits Big Cry Just makes sense to blast some goo in every orifice first it will all last 20 years+ longer, it will look better and you will have less reliability problems from electrics/mechanicals Thumbs Up
Water ingress manual here
https://www.defender2.net/gallery/albums/u...cedure.pdf
City Driver great idea listing the details so others can add and advise.
Make sure your props have nipples and are greased. The engine bracket is obvious when you lift the bonnet if you can't see it at the back of the engine it has been taken off Thumbs Up
Good luck with it all, can't remember who I have pm'd now about all this and where you are but if you ever need any pointers drop me a line or pop down if you are ever in my area. It's all pretty obvious when you start working through it....check also for cracks in your guttering, hairline not a problem (I lacquered mine with little brush suppiled with touch up paint!) but big cracks/gaps need sorting yourself or by dealership. The end capping fit has not been so great on some models I have seen lately and check also the front window to roof fitting (a recent 110 60 plate vehicle I worked on has to have it's whole roof taken off Shocked to be redone due to poor fit!) Big Cry
Just go round the whole thing VERY carefully and check for light coming through from the outside on rear seat boxes, doors etc.....loads more but just go round it methodically Thumbs Up
Oh and get yourself something fun for the motor to cheer you up after all this Laughing I got an LR teddy...err for the kids Whistle but fury dice would do Shocked
Post #93163 7th Oct 2011 6:20pm
T1G UP
My 2 penneth
i think waxoil / dinatrol for ease of maintenance and longevity
security, in all forms
early life oils
heated mirrors!
Post #102690 26th Nov 2011 9:07pm
ZeDefender
T1G UP wrote:
My 2 penneth
early life oils
heated mirrors!
I'm thinking about a heated mirror...
Apologies - now jumping to another thread Thumbs Up Tell someone you love them today because life is short.
Post #102700 26th Nov 2011 9:57pm
CityDriver
Pfff, at least one month delay in the delivery. Can't wait and will start ordering some of the parts for the below... Laughing
CityDriver wrote:
For every newbie�s benefit, I have tried to summarise my take away from this topic and earlier research.
Firstly there are the �must have� items that I will do ASAP after taking delivery of the vehicle:
1) Getting cavities & underside treated: I am thinking of using Dinitrol and getting it done at a �respected� place. I don�t care much about a �100 more or less and don�t have the time and space to do this in January� Will make sure they do all capping�s, bulkhead, doors, rear tub spreaders � does anyone have the full list?
2) Doing the extra rust prevention with ACF-50: Front grill (take off and paint brackets/screws), seat bases/frames, wing mirrors, window latches, headlight rims, and any other internal screws/nuts and hinges. Again � Does anyone have the long list for this one?
3) Fixing the rear mudflap: After all the horror stories I will order the Entreq re-enforcements (http://www.entreq.de/products/reinforcemen...ngers.html). Actually, I will order the now and deliver them at the dealer, so he can fit them before delivery (he, I�m a lazy Censored )
4) Getting an early life oil change for engine, diffs, gearbox & transfer box: By the sounds of it this seems a sensible way of preventing trouble later on
5) Buying mats: I had already specified rubber mats all-round on my new 110, so this is dealt with
Secondly there are some items I am strongly considering doing either ASAP as well or perhaps after some months of driving:
6) Having a tracker fitted: I need to look better at the on-going costs, but it seems a reasonably small investment for a good night�s sleep? Anyone with tips on this topic?
7) Adding �body protection: I already have the soft A-frame bar, hinged lamp guards and rear step bumper specified on my new vehicle. I will consider adding rock and tree sliders
Cool Fitting a noise killer kit: This depends on how I experience the 110 in my first months. I don�t think noise will be an issue for me, but it is an option I will definitely consider if it does become irritating
9) Getting tuition: Fair comment by one person in this topic, but I will consider investing in some decent tuition to learn more about the vehicle
10) Upgrading stereo: Again, I will first do with what I have and see how we move on from there
11) Remapping: I just like a bit of extra power, blame me
12) Installing decent spotlights: I would like them mounted to the soft A-frame bar
Thirdly there are the items I need to check on delivery of the new vehicle.
Please help me complete this list, it would be super helpful to actually just send it to the dealer beforehand, so he can make sure this is all in good order before I pick it up (always easier than arguing later on).
1) Check if the red engine hoist bracket is taken off
2) Check if capping's are sealed to stop water ingress
3) Check if doors are properly hung
4) Check if handbrake is properly tightened
5) Check tyre pressure
6) Check bonnet striker
7) Check key fobs & emergency access code
Lastly:
Zagato wrote:
get the windows sealed by your local window fitter, it's no good having water sitting under your rubbers let alone leaks Rolling Eyes
Post #117855 23rd Jan 2012 7:40pm
ZeDefender
The windscreen problem is serious. I am on a German forum and this is a major point there too. LR don't seem to clean the frame up after welding and then fit a (loose) rubber seal without any kind of sealant. It's a miracle any water stayed out of mine. It also seems to get worse when it's cold as the rubber hardens. I just had to do a botch job on mine as water was pouring in from the roof through the top rubber-to-frame seal and running down the inside exiting behind the dash Shocked
Unfortunately I had no choice to seal (Arbomast) in the wet but at least I'm dry for now (cheers Zag). So worried about corrosion that when I get the chance, I'm going to our Beetle mechanic (old-timer specialist) and getting him to take the whole lot out, tidy the frame, and fit the glass in new rubber with tons of sealant.
Truth is, LR build Defenders like old-timers from new Rolling Eyes
p.s. not sure if you use the name "old-timers" in the UK - cars over 30 years old Wink Tell someone you love them today because life is short.
Post #117872 23rd Jan 2012 8:02pm
when you take delivery
- check each panel for damage,
- check under the seats and carpets for swarf,
- check for leaks underneath.
- make sure they give you a free set of mats.
- make sure the windows go up and down
- check electric front and rear heated windows work
- make sure all recalls have been done
- make sure vehicle is updated to latest firmware
- radio code
- get some security (physical and electronic) #1
- get a rear door strut
- if you go for bigger wheels/tyres - get a wheel carrier
- enjoy it Thumbs Up
Post #117877 23rd Jan 2012 8:13pm
BigRuss
bpman wrote:
- radio code
Yeah but just because its in the document folder it doesn't mean it right, you need to make sure that the serial no. on the code matches the serial no. on the top of the radio!
Yes this is then voice of exsperience talking Whistle
5 days without a radio which included 2 3-4 hour trips, wife wasnt very happy Embarassed Russell
2011MY 110 XS USW Black
Post #117944 23rd Jan 2012 10:29pm
BigRuss wrote:
bpman wrote:
- radio code
did she have to listen to you sing Russ ?
Post #117961 23rd Jan 2012 11:04pm
BigRuss
bpman wrote:
BigRuss wrote:
bpman wrote:
- radio code
You know it Thumbs Up Russell
Post #117962 23rd Jan 2012 11:05pm
Projectblue
firstly, @ Willyeckerslike - best summary I have ever read, especially the belt loops. Took 2 days after swapping from D3 back to a 110 Laughing
The only thing I would state as a personal must is to change the front & rear lights to NAS spec. I'm looking at LED versions this time. This is all about being seen, not being able to see. That's the next bit.
Finally because there are lots of valleys/fords and flooding here, I usually put a snorkel and wading kit on as soon as I can.
Oh, and front & rear recovery points.
Post #118701 26th Jan 2012 6:28pm
Great comments guys....
I've ruined loads of pairs of jeans Laughing Thumbs Up
1st thing I did when I bought my td5.... BFG AT's !
Then you just never stop spending Mr. Green QRZ 2e0vpf
Post #118813 26th Jan 2012 11:05pm
Page 4 of 5 <12345>
