![]() | Home > My Defender > My TD5 90 and other pride and joy.. |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
Looking good VerminHunter
![]() Beer 'n Sex 'n Chips 'n Gravy ![]() |
verminhunter Member Since: 10 Dec 2011 Location: Paignton Posts: 33 ![]() ![]() ![]() |
Iv'e done a twin turbo conversion on a 350Z and it was mental... I used to work at enginetuner.co.uk in Plymouth and did a few tasty mods to Z cars..
Iv'e put about 15k in mods on mine.. but have to sort cosmetics out now.. NISSAN SILVIA S15 SPEC R. Build list.... S15 MFH Vi-pec V44 ECU. Cosworth muliti layer head gasket. Gruppe M carbon Composite Cold air box. Tomei alloy intake pipe. Tomei Pon cam's Blouch hybrid, Garret GT2860RS 3” inlet, Billet 'Disco Potato' Turbocharger. Braided turbo oil & coolant hoses. Tomei Expreme header. Tomei Expreme turbo elbow. A-pexi 3” down pipe and cat replacement pipe. HKS Hi-Power exhaust. Greddy Short Port V2 intake Plenum. Naprec 80mm throttle body. Blitz Super Sound BOV, fitted to cold side. Apex Performance F M I C kit. Splitfire coilpacks. Walbro 255 l/h fuel pump. Sitec fuel pressure regulator. Sitec fuel billet filter. Nismo 740cc injectors. Greddy alloy big wing oil pan. Koyo Alloy 43mm core radiator. Electric fan conversion. Nismo engine mounts. Nismo gearbox mount. Depo boost gauge, inc volt, oil press, oil temp. Nismo Super Coppermix single plate clutch. Billet alloy engine pulleys, stock crank pulley. Ray's Volk 57c Gram Light 17" wheels. Now BBS LM's K-sport 8 pot 330mm front brake kit (performance friction pads). K-sport 4 pot 330mm rear brake kit (Ferodo DS2500 pads). (R33 hub conversion.) Braided stainless steel brake lines. RS-R Super-i 32 way damping /rebound & ride height adjustable dampers. Ti 2000 Titanium alloy springs. Whiteline anti roll bars & links. Nismo front strut brace. Nismo R-tune body kit. Nismo dash cluster. Hel braided clutch hose. Clifford Avant Guard 5.5 Alarm/immobiliser. Momo steering wheel/Momo boss. Carbon fibre cooling panel. Carbon fibre coil-pack cover. Carbon fibre ABS heat shield. Custom made inter-cooler pipes. LED rear light clusters. Nismo tax disc holder. Kenwood DNX 9240BT double din DVD/Sat Nav, bluetooth head unit. ![]() ![]() ![]() |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
15K..... I should be shocked but I think I have spent more on my Defender
It's easy done, 15k is without all the labour costs as Iv'e done it myself.. I dread to think what it would be else @ £60 PH + veg and taties.. ![]() Defenders are just silly money really but they have that appeal so we give in and spend the hard earned.. ![]() |
