![]() | Home > My Defender > My TD5 90 and other pride and joy.. |
do a bit of drifting do we?!
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
verminhunter Member Since: 10 Dec 2011 Location: Paignton Posts: 33 ![]() ![]() ![]() |
No I don't do all that hooligan drifting stuff she is set up for fast road handling and does it very well.. No cheap ebay rubbish fitted, all genuine Japanese tuning parts and fitted by myself.. I love showing the 911, M3/M5, AMG owners that you can with a Nissan.. |
Will take some tomorrow now I have found my camera.. |
fair enough, always did seema waste of tyres TBH
![]() Click image to enlarge [/img] ![]() Click image to enlarge ![]() Click image to enlarge[/img] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 ![]() ![]() |
looks far better without the stickers
I should have taken a photo when I picked it up, there were 7 stickers in each rear window about 6 on the rear, 4 on the inside of the rear door, one in each alpine glass. The man went mad!! I have also had to replace the front wheel bearing, rear gearbox seal, steering bars (bent) affecting the tracking hugely, prop shaft UJ's, all fluids, repair reverse light connection, replace spotlamp relay (fitted upside-down so filled with water!) rewire botched hazard warning switch, re bleed clutch. All in the first month of ownership.. Don't you just love Defenders... and their previous owners who trust their mate who works at a stealership as a fitter to do their maintenance..... ![]() But hey I'm on top of the job now and have a very smooth driving 90 well happy.. He would be sick if he drove it now to find out how it really should be like.. |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385 ![]() ![]() |
x2 ![]() |
![]() Click image to enlarge[/img] I now need a ashtray for the top of the dash before all sorts goes missing down there and add's to the rattles.. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Much better
![]() A few would be interested in your light guards going by another thread ![]() |
Me too ![]() ![]() ![]() ![]() ![]() |
Also good when I can out brake and handle them too, I fitted 356mm discs all round and 8 pot calipers front 6 pot rear. Performance friction pads £328 per set.. ![]() ![]() And RSR Super I Coilovers with Titanium springs, 32 way adjustable rebound/compression damping. Put that with flatshift and launch control it takes a real fancy badge and driver to catch me.. ![]() ![]() ![]() So I can go fast and go anywhere... Now I have the Defender... |
I managed to squeeze two Numax CXV31MF sealed lead acid batteries under the seat today
![]() Got two new ones fro £40 each from a local supplier with 6 months guarantee too.. Was a tight squeeze like but will be pukka for my winch. I'm using a marine spec diode split charger for charging of them just need to get the cables routed nicely to the winch now, Iv'e fitted an isolator switch ready and Anderson plug jumplead set up in the side of the seat box. getting bits and bobs done each day and only minor cuts and grazes up to press.. |
