![]() | Home > Puma (Tdci) > Reversing light |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20999 ![]() ![]() |
Well still haven't bothered to get it sorted just yet
bartsimp Member Since: 18 Jan 2012 Location: France Posts: 41 ![]() ![]() |
Hi,
It looks like I have the same issue, i'll be swapping with fog light tomorrow but fuse (n°14) and bulb are both ok. |
I could never work it out myself so went to main dealer and they fixed it for free ![]() |
Ok, and you don't know what they did at all?
I'm afraid that I forgot to ask at the time. By my own conclusion I think it was the switch on the gearbox either stuck loose or faulty. I checked and tested everything else out that I could. either way they took no time fixing it so doubt it's much wrong. Good luck
Ok, interesting it was a fast fix on their side. Thanks
I tried all combinations of lights swapping during lunch and no luck... I'll try to look under the car but looks like the contactor is at fault.
SteveS Member Since: 05 Oct 2010 Location: Devon & Berkshire Posts: 388 ![]() ![]() ![]() |
Had a similar problem with mine when the switch didn't work one day. Checked the bulb resistance, did the bulb swap - bulb OK. Checked the voltage present on the connector pins - occasionally got 8V rather than 12V - and appeared to be high source resistance - ie not enough grunt to light the bulb.
Looked at where the switch is and the difficulty of getting to it .......put it down for a job for another day. In the meantime noticed that the light lit sometimes but not others - so thought intermittent connection. Put my hand up and wiggled the connector a bit. Not sure this actually worked but after going in and out of gear about 20 or 30 times....the fault cleared. Strangely there was never the flicker you expect with an intermittent - it was either on or off and wasn't affected by wiggling the gearstick or engine load/movement. So summary - I put my problem down to the fact that the switch contacts just got stuck or did not work properly. Having not seen the switch does anyone know if it is mechanically actuated - ie the gearbox pushes a button/closes contacts or whether it is a reed switch/magnetically operated? At the last warranty service had LR look at it - no fault found, but they did change the bulb as a precaution |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17996 ![]() ![]() ![]() |
Mechanical. |
I found since having an LED bulb it was working great all bar I'm not happy with the brightness. I then changed back to the 21w filament bulb and it stopped working again. Today I took my rear step off to check it all out with the multimeter also and found everything present and correct power to all terminals nothing loose ect. I tried not one but two filament bulbs 21w ones both in working order and nothing at all yet I put in the LED and it works. Am I using the wrong wattage bulbs or something?
mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 ![]() |
Following on from Blackwolfs really great info I set about checking why my reversing light was working intermittantly. Here are some pictures of the job which was straight forward although my hands and arms got pretty scratched trying to remove and reinsert the reverse switch. ![]() Access to the switch is below the cubby box, the yellow mark indicates where to find the switch underneath the panel. ![]() Click image to enlarge The cubby removed and the panel beneath is held in by four screws when this is taken out you can see the top of the gearbox. Worth noting a little bit of rust forming at the back of the inspection hatch caused by the metal to metal contact with the hatch lid. This was duely cleaned and prepped prior to closing everything up after doing the switch ![]() Click image to enlarge Looking towards the front left of the gearbox you can just see the switch. ![]() Click image to enlarge Removing and inserting the switch was easier sitting in the drivers seat using my left hand to turn it. ![]() Click image to enlarge Switch removed ![]() Click image to enlarge The switch removed was clean and just needed pushing in and out a few times to ensure full movement. Make sure the switch is a firm spanner fit when reinserted so the ball actuator is pushed in fully to operate the switch when reverse is sellected. ![]() Click image to enlarge I spent a good three hours doing this job, no hurry. At first I found it almost impossible to get my hand in to the space but after a few minutes contorting myself I eventually made progress. Another job jobed, hope this helps anyone with a dead reversing light find the fault. ![]() Mermoto |
That's excellent Mermoto.
![]() ____/🇬🇧🇺🇸\____ _//*⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°*\\_ |
