![]() | Home > Maintenance & Modifications > New reg plate LED ight |
XS Pete
I'll pop some photos up when I fit them, if they don't work well, I'll get them replaced. ![]() bp |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2666 ![]() ![]() ![]() |
A good place to look for alternative bulbs is www.autobulbsdirect.co.uk
The bulbs is type 233 or equivalent These are the rear number plate bulbs recommended for a Defender: http://www.autobulbsdirect.co.uk/233-T4W/?...p;end=rear Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6687 ![]() ![]() ![]() |
DISCO3 site sponsor www.hids4u.co.uk do a wide range of quality LEDs - worth a look if you want to be sure they're not going to fail after a few months.
You can check their feedback on DISCO3 if you like ![]() ![]() ![]() |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 ![]() ![]() ![]() |
I fitted these in my number plate light a few months ago, bit tight, but works a treat pal. |
thanks for the feed back Paul, I had the dispatched email from ultraleds today, so should arrive tomorrow .. ![]() |
here we are ...
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
That looks ok doesn't it
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5982 ![]() ![]() |
Personally think they look better if you leave the spacer out, from in between light and the body
![]() ![]() Click image to enlarge Andy Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Sealed well with black silicon the lamp internal junctions and fixed the lamp base and the plinth with rivnut, this is the results:
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() IID Pro MV License |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 764 ![]() ![]() ![]() |
Is it a straight swap ? Remove the old one and fit the new one ? Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
yes Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
look good daniele, it will be interesting to see how long they last. maybe there was a bad batch previously ?
![]() we will see................. ![]() ![]() IID Pro MV License |
