![]() | Home > Puma (Tdci) > Essential Parts |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2480 ![]() ![]() ![]() |
Non obvious spares: fuel line related items WJN500190-LR016984 Puma 110" SW
Not going to trust Land Rover Assist then
a propshaft would be #1 on my list for sure
![]() also: multimeter, obd reader, portable air, wire, nuts/bolts/cable ties, tubing, tyre repair kit & SAT phone (rental) get a map/list of LR dealers or 4x4 specialists also, make sure you have taken the time to prepare the vehicle, talk to locals to determine any special requirements. |
and make sure the oil pump gasket has been done, the xfer box recall fixed - get these done well before you leave
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17879 ![]() ![]() ![]() |
"Oil pump gasket"? ![]() New one on me - or typo? Can you provide more info? |
you know, the gasket/seal that when it goes you cover the whole engine bay with engine oil |
Molusk Member Since: 20 Dec 2011 Location: Loire Valley Posts: 43 ![]() ![]() ![]() |
vacuum pump you mean? |
yeah, that ... ![]() |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Think 2010 onward have the double seal fitted from new
I have a 2010 and needed the seal doing .. so keep an eye out Zag ... how long would that take you to clean ?????
I just noticed a couple of drops of oil on the floor, then had a look underneath and noticed a small leak around the N/S of the engine near the oil filter housing ... I took it to the dealers and they did the rest, no leaks since .. i thought better to catch it before it completely rust proofed my engine bay
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2673 ![]() ![]() ![]() |
A Land Cruiser ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233 ![]() ![]() ![]() |
Have a word with site sponsor Brendan http://www.4x4overlander.com/ Im sure he will help you with the most common things that go as a man in the know.
Id think as said fuel related items along with prop shaft joints, fan belts, coolant, black tape, gasket glue, filters and oil and possibily some wheel barings at least, as well as the tools to change any of them. That said I went to France in a old 200TDI and took a gear box that I never did use as mine was a little noisy so I may be a little OTT lol. Pete |
