![]() | Home > Td5 > Radiator connections |
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
Do you have a picture ?
| Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698
There should be a pair - one front and one back. They are to connect to the fuel cooler unit.
1988 90 Td5 NAS soft top
2015 D90 XS SW |
| Arbman Al Member Since: 04 Jan 2012 Location: Surrey Posts: 80 |
Can't do pics onto the forum from my iPhone. It's on the drivers side bottom right hand corner. The stub is about 1/2 inch dia and is close to the mounting foot. 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
| landyman40 Member Since: 11 Jan 2012 Location: derbyshire Posts: 29
hi changed my td5 anti freeze this weekend noticed the same thing. its a blank port used on earlier models apparantly as the coolent pipes were slightly different if needed just bore it out . mines running ok with anything connected to it.
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5986
Email me the photo if you need, a.russell@virgin.net , and I will post for you Andy |
Does this work? Help?
http://www.landyzone.co.uk/lz/attachments/...oling1.jpg Andy |
Found this: http://www.lro.com/forum3/viewtopic.php?f=19&t=22803
Seems to explain. I'll check in the morning that it is blocked off. Cheers...Al 1996 Defender 130 converted to TD5 and auto 1975 Triumph Stag 3.0 V8 |
