Home > Maintenance & Modifications > steering guards
Page 4 of 6 <123456>
ZeDefender
JSG wrote:
You can have jate rings and a steering guard fitted to the same holes - it does require the steering guard to have clearance for the jate rings though ......
I have jate rings and I'm still looking for a steering guard I like.
No chance for me - no clearance Sad
Nothing else seems possible, so now the big question:
Would drilling 2 new holes about 2" back from the front of the chassis and fitting jate rings make sense?
Matt Tell someone you love them today because life is short.
Post #112912 6th Jan 2012 3:46pm
BigMike
ZeDefender wrote:
So if you have a basic LR guard fitted, is there anywhere safe on the front where you can be recovered? (by professionals of course).
A quick search found this sort of thing...
Does it make sense?
Already have combi-towing hitch on the back.
I wouldn't have those. The steel of the bumper itself is really thin and bends too easily.
The hitch that someone posted, that's great but absolutely not with a tow hook (for recovery), it needs to have a shackle and heavy duty pin etc.
Jate rings are ok if you use them with a bridle, not so good without, and as someone else said, they are often buried if youre in the s***. A decent winch bumper has good recovery points, like the devon one, and the goodwinch one (when used with spring clip held shackle points. I'd never use a snowplough type guard recovery point on it's own, would always use a bridle and use both eyes and have the pull centred.
Post #112918 6th Jan 2012 4:19pm
I believe those things effectively wrap around the bumper and attach via the bumper mounting bolts rather than through the bumper itself. Darren
Post #112973 6th Jan 2012 7:24pm
leeds
Matt, the answer to drilling holes in your chassis to mount recovery points is basically a big NO NO
The holes for the Jate rings are reinforced inside the chassis.
To fit new recovery points the holes would need to be sleeved and the chassis reinforced with 6 - 8mm plates either side of the chassis. What are German MOT inspectors like with welded plates on chassis?
That swivel recovery eye is probably made by Equipe of Italy. Not sure what thickness the steel bracket is but would guess about 6mm. It fits over the standard bumper and is fixed on the bumper bolt holes. To accommodate the swivel a hole has to be drilled in the bumper. All the recovery forces at the swivel is transferred via the steel bracket to the chassis. No recovery forces go through the bumper
Brendan
Post #113025 6th Jan 2012 9:13pm
ZeDefender
Many thanks Brendan Bow down
Matt
p.s. if ADAC/RAC had to pull me out of a hole from the front end, do you know where they would attach their hook? Tell someone you love them today because life is short.
Post #113048 6th Jan 2012 9:51pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
So, are there any steering guards that will fit with jate rings? I have some but am yet to fit them, thought they utilised the same holes as the steering guard bracketry - therefore, aside from the jate rings being able to fit through the front of the steering guard, are they wide enough? does that make sense Smile 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #113053 6th Jan 2012 9:58pm
mick
just fit one of these
mantec bumper and steering guard
Post #113061 6th Jan 2012 10:07pm
chiefstoker
Out of interest, what sort of loading on your ins. does that set up put on your premium? 2005 TD5 90 Hard Top
Post #113068 6th Jan 2012 10:13pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
got to get one soon botttomed out today Big Cry
Post #113343 7th Jan 2012 10:04pm
leeds
as well as bigger tyres?
Personally I like recovery points to be easily accessible
Brendan
Post #113347 7th Jan 2012 10:12pm
mick
nothing extra took a photo and sent it to them
Post #113536 8th Jan 2012 6:47pm
Zagato
My insurance wasn't increased with my winch etc either Confused
Like the look of the Famous Four one! http://www.famousfour.co.uk/new_parts/part_info.php?partID=13473
Post #113586 8th Jan 2012 8:18pm
leeds
How about this one
£115 + VAT =£138 available from your friendly site sponsor.
Brendan
Post #113612 8th Jan 2012 9:19pm
chiefstoker
Will that fit with jate rings Brendan? 2005 TD5 90 Hard Top
Post #113623 8th Jan 2012 9:59pm
tolley
leeds wrote:
How about this one
Brendan
nice any member discount :wink:
Post #113626 8th Jan 2012 10:02pm
