Home > Puma (Tdci) > Center console removal for changing bulbs
Page 2 of 2 <12
I fitted LEDs in place of the bulbs in mine but it really doesn't work; I have gone back to bulbs.
The problem is that light only comes out the end of the LED so you get one bright spot and the rest is dark. With the more general light of a bulb the illumination is more uniform.
Biggest problem I found was getting a good contact between the capless bulbs and the holder.
It is quite possible to renew the heater control bulbs through the radio aperture without removing the console.
Post #112145 4th Jan 2012 8:22pm
ericvv
Thanks, that last one is a good piece of advise. Will give that a try.
And,..... That kills the idea of trying to use LEDs in the center console. Guess end of this thread Laughing Crying or Very sad You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #112156 4th Jan 2012 8:45pm
not taken mine off yet, but when I do, they'll be replaced Thumbs Up
Post #112175 4th Jan 2012 9:15pm
ericvv
Had a long conversation with Autobritt (local LR dealer) and in the end decided that we are going to leave the heater matrix fix to solve the colder air at the right side as it is. Even if the car is out of factory warranty now, Autobritt have records that I reported the problem 2 years back already, and LR would have agreed to still today do the fix as described in Topix, but as we have seen in a different thread, it would require dismantling the entire dashboard which a monster job.
And the risk being that while my SVX seems one of the well assembled ones, after three years and 55k km no trace of parasite noises, this might change with such a massive job to take half the front apart and reassemble it.
So decided to leave it as is, I will continue to open the front window as required to keep it cool enough my side, while the misses side is warm Laughing .
But Autobritt were kind enough to offer me that when my Black Wood center console will arrive from Startech, they will remove the existing SVX front and install the new one, plus change the broken dash light bulbs at their expense. Smile
Will also have them change all the car's fluids then, engine, gear/transfer box, diffs.
So halfway happy. Confused You never actually own a Defender. You merely look after it for the next generation.
Post #112466 5th Jan 2012 3:27pm
T1G UP
if you'd like to sell the centre bit pm me!
Post #112467 5th Jan 2012 3:36pm
ericvv
Will keep it in mind, but first want to see the result, and the new console won't arrive for weeks I think. My existing SVX one (alu coloured) in any case is spic 'n span.
Rgds, Eric You never actually own a Defender. You merely look after it for the next generation.
Post #112468 5th Jan 2012 3:40pm
T1G UP
Rgds, Eric
Ok, overread the svx bit....that reads very expensive to me!
any idea how much an ordinary one is? i can get it painted
Post #112469 5th Jan 2012 3:42pm
ericvv
Post #112484 5th Jan 2012 4:28pm
T1G UP
ericvv wrote:
Not sure if there would be a big price difference between a regular and a SVX center console cover. They both are just a piece of molded plastic.
Rgds, Eric
cool, well let me have a price if you decide to sell Thumbs Up
Post #112488 5th Jan 2012 4:34pm
that was a fair result from Philippe / AutoBritt Thumbs Up
Post #112543 5th Jan 2012 7:09pm
Merlin
Puma dashboard lamps are sold here:
http://www.vehicle-wiring-products.eu/VWP-.../bulbs.php
Look for type 286. 1.2 Watt.
Fiddly to fit. I dropped two down the back and I can't get to them. Doh!
Merlin
Post #280533 8th Nov 2013 12:00pm
Expensive from VWP though, I bought ten from my local factors for 35p each.
Any good factor should stock these, they're standard bulbs.
Post #280535 8th Nov 2013 12:39pm
Genuine is around the same price.as that, I'd always go genuine for these because they are so cheap full stop. ____\We|Will|Win/___
____/πŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ\____
Post #280536 8th Nov 2013 12:48pm
The ones I bought for 35p are actually high quality branded products from one of the largest and best known manufacturers of such things, quite possibly OEM.
They definitely didn't come in a blue box.
Post #280545 8th Nov 2013 2:06pm
Page 2 of 2 <12
