![]() | Home > Puma (Tdci) > Center console removal for changing bulbs |
Thanks, that last one is a good piece of advise. Will give that a try. And,..... That kills the idea of trying to use LEDs in the center console. Guess end of this thread ![]() ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
not taken mine off yet, but when I do, they'll be replaced
Had a long conversation with Autobritt (local LR dealer) and in the end decided that we are going to leave the heater matrix fix to solve the colder air at the right side as it is. Even if the car is out of factory warranty now, Autobritt have records that I reported the problem 2 years back already, and LR would have agreed to still today do the fix as described in Topix, but as we have seen in a different thread, it would require dismantling the entire dashboard which a monster job.
And the risk being that while my SVX seems one of the well assembled ones, after three years and 55k km no trace of parasite noises, this might change with such a massive job to take half the front apart and reassemble it. So decided to leave it as is, I will continue to open the front window as required to keep it cool enough my side, while the misses side is warm ![]() But Autobritt were kind enough to offer me that when my Black Wood center console will arrive from Startech, they will remove the existing SVX front and install the new one, plus change the broken dash light bulbs at their expense. ![]() Will also have them change all the car's fluids then, engine, gear/transfer box, diffs. So halfway happy. ![]() http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
if you'd like to sell the centre bit pm me! |
Will keep it in mind, but first want to see the result, and the new console won't arrive for weeks I think. My existing SVX one (alu coloured) in any case is spic 'n span. Rgds, Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Ok, overread the svx bit....that reads very expensive to me! any idea how much an ordinary one is? i can get it painted |
Not sure if there would be a big price difference between a regular and a SVX center console cover. They both are just a piece of molded plastic.
cool, well let me have a price if you decide to sell ![]() |
that was a fair result from Philippe / AutoBritt
Merlin Member Since: 30 Oct 2010 Location: Newmarket Posts: 982 ![]() ![]() |
Puma dashboard lamps are sold here:
http://www.vehicle-wiring-products.eu/VWP-.../bulbs.php Look for type 286. 1.2 Watt. Fiddly to fit. I dropped two down the back and I can't get to them. Doh! Merlin |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17911 ![]() ![]() ![]() |
Expensive from VWP though, I bought ten from my local factors for 35p each.
Any good factor should stock these, they're standard bulbs. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20937 ![]() ![]() |
Genuine is around the same price.as that, I'd always go genuine for these because they are so cheap full stop. ____\We|Will|Win/___
____/π¬π§πΊπΈ\____ _//*β½οΈπ’οΈβοΈπ§°*\\_ |
The ones I bought for 35p are actually high quality branded products from one of the largest and best known manufacturers of such things, quite possibly OEM.
They definitely didn't come in a blue box. |
