Home > Puma (Tdci) > wtd auxillary lighting loom and plug
LR90XS2011
Wanted geniune spot light wiring loom and switch plug (have got the genuine switch) DEFENDER 90 TDCI XS,
Post #111216 1st Jan 2012 12:13pm
K9F
Any good? Not genuine but functional at reasonable cost!
http://www.douglassmotors.co.uk/4x4/Auxhil...rness.html If you go through life with your head in the sand....all people will see is an ar5e!!
Post #111239 1st Jan 2012 1:24pm
mse
Why genuine - just make the loom yourself, much more flexible Mike
Post #111261 1st Jan 2012 3:24pm
Lorryman100
Pity, I just sold one on here.
Also the OEM loom saves a lot of time in building your own one, and if a warranty claim was to arise because of it, you are covered. Thumbs Up
Post #111262 1st Jan 2012 3:44pm
LR90XS2011
thanks to those that have responded
I want the plug for the back of the switch more than anything but would prefer the whole loom if anyone has one or knows where I can get one without spending £300 on an LR lighting kit from a dealer DEFENDER 90 TDCI XS,
Post #111313 1st Jan 2012 8:12pm
TJ101
Fully understand the desirably of a genuine loom, even though it a simple loom
Sure Land Rover do, or they certainly did supply the loom separately, as i had one 2004/5 for mine, and has been removed and refitted in all the defenders since !! thought they were £60 odd, but what they are now, if still available ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #111322 1st Jan 2012 8:40pm
Lorryman100
What you need is STC 53208 priced at about £135 from the dealers. It includes the loom and fascia switch. Thumbs Up
Post #111326 1st Jan 2012 8:58pm
LR90XS2011
lorryman 100
thanks loads that looks like what I need
all the best Rob DEFENDER 90 TDCI XS,
Post #111378 2nd Jan 2012 7:18am
PaulMc
Details of the switch connector and how to wire it are here -
http://www.defender2.net/forum/topic552.ht...p;start=15
and here -
http://www.defender2.net/forum/topic795.html
. Paul.
Post #111435 2nd Jan 2012 12:42pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Here Thumbs Up
http://www.ebay.co.uk/itm/270763766638?ssP..._500wt_969 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #111496 2nd Jan 2012 4:26pm
LR90XS2011
thanks for all the replies and Glynparry whom PMd me
I have now ordered a genuine loom despite the additional cost and Im going down the NAKATANENGA route with four 70mm spots in the bumper and will post some photos when its all done. Just waiting for all the parts to arrive to do it. DEFENDER 90 TDCI XS,
Post #111760 3rd Jan 2012 5:28pm
LR90XS2011
thanks to all who helped with this
I purchased the LR loom STC 53208 and its just the job, unfortunately its come with no instructions and I dont appear to have access to TOPIX. If anyone has instructions for fitting this to a PUMA could you kindly post them or PM me with them.
Please and thanks in advance DEFENDER 90 TDCI XS,
Post #113151 7th Jan 2012 8:44am
TJ101
Just had a quick look to see if i had it on file ?? but don't look like it
Sorry Rob but only a quick reply, to hopefully get you started !!
Its not that hard, when you have done it a few times Whistle
Mine was originally off a TD5, but sure they are all the same (now on the 4the Puma !!?
I split the loom into 3 direction in the engine bay near the grommet mentioned below, 2 lamps leads forward, the blue lead and the switch lead through the bulkhead, the power and relay lead down and back to the battery box
The blue lead goes up behind the dash to the main beam feed (blue)
The lead with the multi plug also goes that way to the centre console, as the main on/off switch (mine in the spare hole next to the screen heater
You need to pass the loom through the bulkhead, mine is in the grommet near to the passenger foot well, access thought that lower removable panel,,
I started from the front and worked backwards, you will have the relay etc after a black plastic nut etc, this part of the loom goes down the bulkhead, and under the car to the battery box, (take the spade terminal out of the relay socket) California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #113163 7th Jan 2012 9:14am
PaulMc
This link should take you directly to the .pdf file -
http://topix.landrover.jlrext.com/topix/service/document/70573
If that doesn't work for you, PM me your email address and I'll send the document to you.
. Paul.
Post #113179 7th Jan 2012 11:03am
TJ101
Yep, thats the one i have ?? somewhere, TD5 but the idea is the same Smile California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #113180 7th Jan 2012 11:07am
