![]() | Home > Puma (Tdci) > wtd auxillary lighting loom and plug |
| LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3680
Wanted geniune spot light wiring loom and switch plug (have got the genuine switch) DEFENDER 90 TDCI XS,
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
Any good? Not genuine but functional at reasonable cost!
http://www.douglassmotors.co.uk/4x4/Auxhil...rness.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
| mse Member Since: 06 Apr 2008 Location: UK Posts: 5117
Why genuine - just make the loom yourself, much more flexible Mike
thanks to those that have responded
I want the plug for the back of the switch more than anything but would prefer the whole loom if anyone has one or knows where I can get one without spending £300 on an LR lighting kit from a dealer DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
| TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752
Fully understand the desirably of a genuine loom, even though it a simple loom
Sure Land Rover do, or they certainly did supply the loom separately, as i had one 2004/5 for mine, and has been removed and refitted in all the defenders since !! thought they were £60 odd, but what they are now, if still available ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
What you need is STC 53208 priced at about £135 from the dealers. It includes the loom and fascia switch.
Click image to enlarge |
lorryman 100
thanks loads that looks like what I need all the best Rob DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
| PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 511
Details of the switch connector and how to wire it are here - http://www.defender2.net/forum/topic552.ht...p;start=15 and here - http://www.defender2.net/forum/topic795.html . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
| fekete Member Since: 24 Dec 2008 Location: Here on the other end of the computer Posts: 3626
Here
http://www.ebay.co.uk/itm/270763766638?ssP..._500wt_969 NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
thanks for all the replies and Glynparry whom PMd me
I have now ordered a genuine loom despite the additional cost and Im going down the NAKATANENGA route with four 70mm spots in the bumper and will post some photos when its all done. Just waiting for all the parts to arrive to do it. DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
thanks to all who helped with this
I purchased the LR loom STC 53208 and its just the job, unfortunately its come with no instructions and I dont appear to have access to TOPIX. If anyone has instructions for fitting this to a PUMA could you kindly post them or PM me with them. Please and thanks in advance DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
Just had a quick look to see if i had it on file ?? but don't look like it
Sorry Rob but only a quick reply, to hopefully get you started !! Its not that hard, when you have done it a few times Mine was originally off a TD5, but sure they are all the same (now on the 4the Puma !!? I split the loom into 3 direction in the engine bay near the grommet mentioned below, 2 lamps leads forward, the blue lead and the switch lead through the bulkhead, the power and relay lead down and back to the battery box The blue lead goes up behind the dash to the main beam feed (blue) The lead with the multi plug also goes that way to the centre console, as the main on/off switch (mine in the spare hole next to the screen heater You need to pass the loom through the bulkhead, mine is in the grommet near to the passenger foot well, access thought that lower removable panel,, I started from the front and worked backwards, you will have the relay etc after a black plastic nut etc, this part of the loom goes down the bulkhead, and under the car to the battery box, (take the spade terminal out of the relay socket) California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
This link should take you directly to the .pdf file - http://topix.landrover.jlrext.com/topix/service/document/70573 If that doesn't work for you, PM me your email address and I'll send the document to you. . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Yep, thats the one i have ?? somewhere, TD5 but the idea is the same
