22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3153 ![]() ![]() ![]() |
Yesterday I washed the remains of Salisbury plan off the 110. 2011 110 USW
1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
Yesterday I just added more mud to mine, Herefordshire mud this time(basic undersealing
Had a run over the plains last night with BigRuss .. very dark and very muddy
GPS came in very handy last night, the plains are very different in the dark. MrsBigRuss took some pics |
Yep very slippery at times, surprised not to see any other 4x4's out last night Russell
2011MY 110 XS USW Black |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
Been up the Peaks today, went for a 3.5hr 'stroll'
![]() The 90 just got used for slinging wet and muddy gear in ![]() |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
As good an idea as that sounds ... you have no idea how difficult it would be to arrange [vetting/passes/vehicle shakedowns, etc etc] ![]() |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
took the kids to see Puss in Boots in Roscommon (3D helps to make kids movies bearable) then a two hour ordeal following the missus around shops with only the carrot of KFC for tea on the way home - this is what middle aged dad's Bank holidays has come to. Filled up on the way back 24.4 mpg.; Marvelled at how 6th gear is usable from 50mph on the steepest of inclines and spent the evening consuming the Hobgoblin ale bought in Tescos. Happy new year fellow consumers !
finished fitting the 2 front door rubber seals and managed to save the fragile door cards (again
![]() the inside of my doors already had some brown sealant, so I sprayed some dinitrol inside too. Then I fitted the entreq fuel cooler guard .. I used small ramps and axle stands to get my rivnut tool under the vehicle. 1. check the guard will fit then spray the this part with dinitrol (or similar) (picture is black and white - daughter was fiddling with the camera!) ![]() Click image to enlarge 2. dinitrol the holes, then fit the 4 rivnuts to the cross member, then dinitrol again ![]() Click image to enlarge 3. remove front anti-roll bar fixing ![]() Click image to enlarge 4. place the plastic washers onto the dinitrolled area on the top side of the guard. 5. using the 2 front a/r bar bolts, offer up the guard and do nuts up finger tight 6. fit the 4 rear hex bolts through the plate, plastic washers and into the rivnuts ![]() Click image to enlarge 7. tighten up the a/r bar bolts ![]() Click image to enlarge 8. re-check all the nuts and bolts then dinitrol the fixings ![]() Click image to enlarge 9 fit the fuel hose clip 10 sit back and admire the guard ![]() Click image to enlarge Last edited by bpman on 2nd Jan 2012 3:29pm. Edited 2 times in total |
Just fitted a better antenna for the HF. QRZ 2e0vpf
What HF set up have you got Greeni ?
Bob |
I went for a basic 706 Icom, it'll do for now! I'm just doing my foundation licence. QRZ 2e0vpf
Lishlandy Member Since: 26 Oct 2011 Location: High Wycombe Posts: 941 ![]() ![]() ![]() |
Fitted Alpine speakers to replace the standard jobbies, cracking on with replacing my broken radio antenna tomorrow after work with a flexi one, one less chrome bit on my defender!!!
drove to Lough Key forest park in Boyle. A good walk around the lake followed by hot chocolates in the visitor centre. This place is cris-crossed with forest walks and I was itching to take the Defender along them but alas not allowed. I totally love driving this vehicle and I envy anyone whose job involves daily use of one
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
been laning in a friends G4 black td5 110 around whiltshire / hampshire in a decent group. very nice but slippery and scratchy
