Home > Wheels & Tyres > Help!!!Wolf Wheel Problems |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
I know on some land rovers you need to change the studs as they are too short for wolf wheels. sounds like yours is one of the ones that need to studs changing.
28th Dec 2011 3:30pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Should be just short of flush with standard studs, put a photo up Original Member Pie n Pea Club.
110 HCPU Tipper |
28th Dec 2011 4:02pm |
Best I can do at the moment
Click image to enlarge Original Member Pie n Pea Club. 110 HCPU Tipper |
28th Dec 2011 4:09pm |
Dean Watson Member Since: 17 Jul 2011 Location: Derby Posts: 254 |
Hi mate
Yes they are just short, 1 or 2mm, of flush do you think thats ok? i am torqueing up to 125 ft/lbs so i cant see them coming off,plus 1 is a locking nut so thats longer than the others. Thinking back when i had a 200tdi i put d1 steel wheels on it and i think they were the same! Dean |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1746 |
Wolf wheels are alot heavier than standard and therefore need a longer stud as the steel around stud holes is thicker and hence needs to be stronger. When changing hubs need to be removed. If done carefully all you'll need extra will be some new flange gaskets. I have just done this swap and will be fitting my new wolfs tomorrow hopefully, if the new genuine nuts have arrived.
28th Dec 2011 4:37pm |
Standard studs are fine in my humble opinion, early land rovers around 93 had shorter studs. Do a search round the internet and read the different opinions. Original Member Pie n Pea Club.
110 HCPU Tipper |
28th Dec 2011 5:03pm |
Isnt there something to do with a mark on the end of the stud? If its got a bit stamped on it its ok and if it hasnt then they need replacing with longer ones?
Pete |
28th Dec 2011 6:07pm |
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 |
Dean,
Just checked mine - threads sit inside nuts circa 1mm, can get my finger nail inside edge of nut. Never had a problem in the last 2 years on a TD5. Steve Defender 90 TD5 Station Wagon Discovery 3 HSE BMW 330i Coupe |
Buzz Member Since: 11 Oct 2011 Location: Inverness Posts: 235 |
Er, phone Craddocks workshop and check?
28th Dec 2011 6:09pm |
Hi
yes thought of that and tried but guess what there shut till the 3rd and i had time to swap today, plus dont want to get fobbed off by craddocks. I ve done a search and it seems even the mod dont use the longer stud length and there have been no reported problems. Yes i could swap studs but then come spring when i want to swap back id need shorter studs for the boosts and swapping stud again would be a pain in the arse. |
28th Dec 2011 6:29pm |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3747 |
Before changing to the Mack 5 rims, I use wolf steels after bending disco wheels for a past time when use hard !!! off road,,
Ran with the short studs, never a problem California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
28th Dec 2011 6:48pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6041 |
Brand new from the factory with HD steel rims they have the normal length studs on, with the 1~2mm depth thing.
No problem at all. |
28th Dec 2011 6:53pm |
looks like your ok with std studs.
28th Dec 2011 8:01pm |
Phew
Thanks a lot all, didnt really want to be taking 5 tyres and rims back to cannock, Cheers Deano |
29th Dec 2011 10:36am |
