Home > Wheels & Tyres > Help!!!Wolf Wheel Problems
Dean Watson
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Help
Can anyone give me any advice, ive just been out fitting set of wolf wheels to my 2011 my xs dc, i was told by john craddock where i got the wheels and tyres from and by other forum members that they would fit right on.
It seems that the wheel stud is 2 or 3 threads from protruding through the nut, is this normal? or ok? can anyone help please.
Thanks
Deano
Post #110366 28th Dec 2011 3:24pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
I know on some land rovers you need to change the studs as they are too short for wolf wheels. sounds like yours is one of the ones that need to studs changing.
Post #110367 28th Dec 2011 3:30pm
willy eckerslike
United Kingdom 2007 Defender 110 Puma 2.4 HCPU Keswick Green
Should be just short of flush with standard studs, put a photo up Original Member Pie n Pea Club.
110 HCPU Tipper
Post #110371 28th Dec 2011 4:02pm
willy eckerslike
Best I can do at the moment
110 HCPU Tipper
Post #110372 28th Dec 2011 4:09pm
Dean Watson
Hi mate
Yes they are just short, 1 or 2mm, of flush do you think thats ok? i am torqueing up to 125 ft/lbs so i cant see them coming off,plus 1 is a locking nut so thats longer than the others.
Thinking back when i had a 200tdi i put d1 steel wheels on it and i think they were the same!
Dean
Post #110373 28th Dec 2011 4:09pm
Romadog
Wolf wheels are alot heavier than standard and therefore need a longer stud as the steel around stud holes is thicker and hence needs to be stronger. When changing hubs need to be removed. If done carefully all you'll need extra will be some new flange gaskets. I have just done this swap and will be fitting my new wolfs tomorrow hopefully, if the new genuine nuts have arrived.
Post #110377 28th Dec 2011 4:37pm
willy eckerslike
Standard studs are fine in my humble opinion, early land rovers around 93 had shorter studs. Do a search round the internet and read the different opinions. Original Member Pie n Pea Club.
110 HCPU Tipper
Post #110382 28th Dec 2011 5:03pm
Zinke
Isnt there something to do with a mark on the end of the stud? If its got a bit stamped on it its ok and if it hasnt then they need replacing with longer ones?
Pete
Post #110393 28th Dec 2011 6:07pm
stevie d
United Kingdom 2003 Defender 90 Td5 SW Alpine White
Dean,
Just checked mine - threads sit inside nuts circa 1mm, can get my finger nail inside edge of nut.
Never had a problem in the last 2 years on a TD5.
Steve Thumbs Up Defender 90 TD5 Station Wagon
Discovery 3 HSE
BMW 330i Coupe
Post #110394 28th Dec 2011 6:07pm
Buzz
2010 Defender 110 Puma 2.4 DCPU Tonga Green
Er, phone Craddocks workshop and check?
Post #110395 28th Dec 2011 6:09pm
Dean Watson
Hi
yes thought of that and tried but guess what there shut till the 3rd and i had time to swap today, plus dont want to get fobbed off by craddocks.
I ve done a search and it seems even the mod dont use the longer stud length and there have been no reported problems.
Yes i could swap studs but then come spring when i want to swap back id need shorter studs for the boosts and swapping stud again would be a pain in the arse.
Post #110403 28th Dec 2011 6:29pm
TJ101
Before changing to the Mack 5 rims, I use wolf steels after bending disco wheels for a past time when use hard !!! off road,,
Ran with the short studs, never a problem California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #110406 28th Dec 2011 6:48pm
Brand new from the factory with HD steel rims they have the normal length studs on, with the 1~2mm depth thing.
No problem at all.
Post #110408 28th Dec 2011 6:53pm
stevie d
looks like your ok with std studs.
Discovery 3 HSE
BMW 330i Coupe
Post #110422 28th Dec 2011 8:01pm
Dean Watson
Phew
Thanks a lot all, didnt really want to be taking 5 tyres and rims back to cannock,
Deano
Post #110523 29th Dec 2011 10:36am
