![]() | Home > Puma (Tdci) > Oil . . . . . |
the shareholders ![]() |
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1296 ![]() ![]() ![]() |
Castrol's website now recommends Edge 0-30 for the Puma.
Axel Member Since: 22 Jun 2011 Location: Bochum Posts: 107 ![]() ![]() ![]() |
My Owner's Manual just says: SAE 5W-30 ..... No additional specs or brands mentioned ....
![]() Axel |
which castrol edge ? which puma (2.2 or 2.4) ? |
Remember that A5/B5 (low HTHS) is ONLY FOR fuel economy!!!!!
IS ALWAYS BETTER A HIGH HTHS OIL!!!!!!! Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2488 ![]() ![]() ![]() |
Yes, but usually a higher HTHS goes along with higher kinematic viscosity. So in this way you can step on the excesive wear zone for an engine designed to run with low visc oils. Solution: use a "true" synth Group V oil. Puma 110" SW ............................................................. Earth first. Other planets later |
MD5 Member Since: 02 May 2011 Location: Italy Posts: 143 ![]() ![]() |
Which one you suggest ? What do you think about the Mobil 1 5W-30 ESP ? |
I think dgardel has been using such Mobil 1. The other ones are Motul Xmax 5w-30 or Motul LL 025B. Puma 110" SW
just normal edge as opposed to turbo diesel edge. It doesn't mention engine size but I guess that covers both engines because until recently it advised Magnatec and then changed presumably because of the 2.2 DPF requiring a higher grade oil. I would therefore conclude that as edge is superior (and dearer) than Magnatec its OK for both. But I will continue to use Magnatec as I bought gallons of it dirt cheap (and so did some of the other guys I think when Halfords were giving it away recently ![]() |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 ![]() ![]() |
Magnatec (Trade name GTX Professional) 5w30 for the 2.4 and Td5 - To Ford WSS-M2913-B (or C)
Edge 5w30 for the 2.2 with DPF to Ford WSS-M2C934-B |
![]() ![]() ![]() ![]() I use also (now into engine) Castrol EDGE 5W-30 A3/B3 A3/B4 C3 THIS NIGHT I' WRITE SAME DATA AND COMPARISON ABOUT MY CHOICES Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 ![]() ![]() ![]() |
Ha I love this place, a simple question, a simple answer, no
I have some Castrol Edge A5/B5 0w30 - not going to use it until my warranty expires although it is a better spec that magnatec A1
Is that a low SAPS? I stay away from those. Puma 110" SW ............................................................. Earth first. Other planets later |
