![]() | Home > Puma (Tdci) > Oil . . . . . |
Jammer600 Member Since: 27 Feb 2011 Location: Bath/Warminster Posts: 306 ![]() ![]() ![]() |
Is it castrol edge I have to put in my engine?
Seriously, do a search, there are hundreds of threads about this
stevie d Member Since: 09 Nov 2009 Location: Bishops Stortford Posts: 342 ![]() ![]() ![]() |
Mike,
It's a forum, folk are allowed to ask questions..... Some folk may even be keen to answer them. Steve ![]() Discovery 3 HSE BMW 330i Coupe |
Yes Stevie d!! Well put!! Magnatec it is!
mse Member Since: 06 Apr 2008 Location: UK Posts: 5111 ![]() ![]() ![]() |
Surely its not the brand its the spec thats important first
Great - absolutely fantastic bit of kit.
And it deciding to warm itself in the mornings is a treat ![]() the infotainment system did need an update as it would occasionally crash after having the TV on its a hard life ![]() Thanks for asking Mike |
at the moment and if you have LR warranty, a 2.4 needs to comply with the ford oil specification, and there are no castrol edge products that conform. so i'm using magnetec until my warranty expires (oil change every 6 months).
once the warranty expires, there is an edge product a5/b5 for volvos that I am going to try, its got more protective qualities that magnatec (because it does not break down as quickly) TJ may have a good perspective on this specific oil ? |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2489 ![]() ![]() ![]() |
why do you stick to Castrol? There are a5/b5 oils meeting the requiered spec, eg. Motul specific 913C, Motul eco energy 5w-30 etc, the latter with higher HTHS values. Anyway, in this case a5/b5 is better than a1/b1.
Since I`m out of warranty, I do my own oil blend which is low vis enough to meet the 5w-30 oil parameters and shows no wear and oil break down (oxidation and nitration) as when an a1/b1 oil is used ![]() ............................................................. Earth first. Other planets later |
Guess who owns Castrol ? |
Some queens I guess. Puma 110" SW
Castrol Oil does comply with the Ford spec for the 2.4 engine, i still have 5l if you want to see - it also happens to be the same as the fiesta tdci oil Its the retail oil for the current line up - mainly the Jag TDV6 that their isnt a retail castrol oil on the market (you can get a shell and another one) Mike |
castrol magnatec complies, or are you saying that there is an edge oil that complies ? |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 ![]() ![]() ![]() |
I know I know ![]() 2011MY 110 XS USW Black |
Magnatec is the one we have that complies...never looked at the edge Mike |
