|  | Home > Maintenance & Modifications > at 23:00 CET first Webasto (water) start-up!!!! |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586    |
 1st attempt diesel line goes full......
 2nd attempt.......... FIRE!!!!!!!!!! Great moment........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition   IID Pro MV License | ||
|  23rd Dec 2011 11:08pm |
| T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101      | get a video up!
 to warm for a heater here! | ||
|  23rd Dec 2011 11:12pm |
| Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505      |
 Not all of Italy is hot  | ||
|  24th Dec 2011 1:31am |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069    | gets flippin cold in the winter especially around the alps    beautiful though .. DG's posted pictures from his travels last Christmas/New Year .. lots of snow   and congrats Daniele ... do you have photos of the installation ? did you use the entreq kit ? | ||
|  24th Dec 2011 7:44am |
| cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336      | Good man - enjoy a toasty warm Christmas    | ||
|  24th Dec 2011 9:23am |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586    | In my area it is normal to have -3, -6 C and my fatherl in love live closer to Cortina, into the Alps and last years we got  -22 C......
 Yes I used the entreq fitting kit (daily drivers one). Soon I'll post same photos Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition   IID Pro MV License | ||
|  24th Dec 2011 9:25am |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069    | Daniele - so the daily drive webasto kit does not touch the entreq fuel cooler guard ? | ||
|  24th Dec 2011 9:36am |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785      | we even got as lower temperatures of -20 C in feb this year in Aberdeen Russell
 2011MY 110 XS USW Black | ||
|  24th Dec 2011 10:59am |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253    | Same here, and that was in Lancashire.  A year ago it was -18 here at 7pm , and in the morning the outside gauage said it had been down to -21. Amazing really.
 Still, didn't have any starting issues though. | ||
|  24th Dec 2011 12:13pm |
 No touch areas, the heater is positioned completely "over" the crossmember, the entreq fuel cooler guard is fixed under (see the nut insert on crossmember), and it protects very well the heater from splash and dirt.......   Click image to enlarge   Click image to enlarge Installed also the by-pass valve for do not decrease the original cabin heater efficiency she the heater is switched off   Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition   IID Pro MV License | ||
|  24th Dec 2011 12:15pm |
| BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253    | Daniele, I guess for driving though you have a cap for the exhaust?
 I love your set up and I know with your attention to detail it will be exactly right, but for me, for driving offroad there is no way I would put one under there. | ||
|  24th Dec 2011 12:21pm |
| mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326  |
 Nice job :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated   | ||
|  24th Dec 2011 3:56pm |
| TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752      | I had a Webasto on a TD5 90 i had,,
 Excellent bit of kit,, even had the remote control set up,, took 10 mins or so , was even connected to a hot water shower system   Tried to justify the set up on the Puma,, but does not get the use to warrant the cost !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK | ||
|  24th Dec 2011 4:08pm |
 The only cons is the lower position.... but I use my car for light off-rad The pros are the very short water pipes length so you have a very high heater efficiency and the accessibility for the future maintenance/checking operation. For the fuel tank accessibility I have done a "hole" directly on the rear floor and covered by a "strong" 3mm aluminium plate screwed with rivet nut inserts and foam gasket   the ending results is similar to this one....   Click image to enlarge with this pickup   Click image to enlarge   Click image to enlarge For the kind of use that I do is the best compromise, I'm thinking about that a lot of months and finally........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition   IID Pro MV License Last edited by dgardel on 24th Dec 2011 4:54pm. Edited 2 times in total | ||
|  24th Dec 2011 4:41pm |
| Posting Rules
