Home > Maintenance & Modifications > at 23:00 CET first Webasto (water) start-up!!!!
dgardel
Italy
1st attempt diesel line goes full......
2nd attempt.......... FIRE!!!!!!!!!!
Great moment........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #109608 23rd Dec 2011 11:08pm
T1G UP
get a video up!
to warm for a heater here!
Post #109610 23rd Dec 2011 11:12pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
it does seem ironic that you live in the wonderful country of Italy that always seems sun drenched and warm to me and you have a Webasto Confused
how fats does it heat up the cab and does it heat the engine as well? BM52
Post #109611 23rd Dec 2011 11:12pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Not all of Italy is hot Rolling Eyes
Post #109624 24th Dec 2011 1:31am
gets flippin cold in the winter especially around the alps Thumbs Up beautiful though .. DG's posted pictures from his travels last Christmas/New Year .. lots of snow Thumbs Up
and congrats Daniele ... do you have photos of the installation ? did you use the entreq kit ?
Post #109638 24th Dec 2011 7:44am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
Good man - enjoy a toasty warm Christmas Thumbs Up
Post #109665 24th Dec 2011 9:23am
dgardel
Italy
In my area it is normal to have -3, -6 C and my fatherl in love live closer to Cortina, into the Alps and last years we got -22 C......
Yes I used the entreq fitting kit (daily drivers one).
Soon I'll post same photos Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #109667 24th Dec 2011 9:25am
Daniele - so the daily drive webasto kit does not touch the entreq fuel cooler guard ?
Post #109669 24th Dec 2011 9:36am
BigRuss
we even got as lower temperatures of -20 C in feb this year in Aberdeen Russell
2011MY 110 XS USW Black
Post #109702 24th Dec 2011 10:59am
BigMike
Same here, and that was in Lancashire. A year ago it was -18 here at 7pm , and in the morning the outside gauage said it had been down to -21. Amazing really.
Still, didn't have any starting issues though.
Post #109723 24th Dec 2011 12:13pm
dgardel
Italy
No touch areas, the heater is positioned completely "over" the crossmember, the entreq fuel cooler guard is fixed under (see the nut insert on crossmember), and it protects very well the heater from splash and dirt.......
Installed also the by-pass valve for do not decrease the original cabin heater efficiency she the heater is switched off
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #109725 24th Dec 2011 12:15pm
BigMike
Daniele, I guess for driving though you have a cap for the exhaust?
I love your set up and I know with your attention to detail it will be exactly right, but for me, for driving offroad there is no way I would put one under there.
Post #109726 24th Dec 2011 12:21pm
mermoto
Nice job :thumbsup:
Post #109766 24th Dec 2011 3:56pm
TJ101
I had a Webasto on a TD5 90 i had,,
Excellent bit of kit,, even had the remote control set up,, took 10 mins or so , was even connected to a hot water shower system Thumbs Up
Tried to justify the set up on the Puma,, but does not get the use to warrant the cost !! California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
Post #109767 24th Dec 2011 4:08pm
dgardel
Italy
The only cons is the lower position.... but I use my car for light off-rad
The pros are the very short water pipes length so you have a very high heater efficiency and the accessibility for the future maintenance/checking operation.
For the fuel tank accessibility I have done a "hole" directly on the rear floor and covered by a "strong" 3mm aluminium plate screwed with rivet nut inserts and foam gasket
the ending results is similar to this one....
with this pickup
For the kind of use that I do is the best compromise, I'm thinking about that a lot of months and finally........ Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #109775 24th Dec 2011 4:41pm
