Home > Puma (Tdci) > engine management light from unplugged MAF - std behaviour?
OrangeAlpine
United Kingdom 2013 Defender 90 Puma 2.2 HT Alpine White
evening all! This is more of a general query as the behaviour from this engine (2.2 Tdci) is very different from the Disco TD5 that I'm used to Shocked
So, I fitted a new air filter (K&N) today as part of my long list of "things to tidy up" on this car having owned it for 4 weeks now and I forgot to re-plug in the MAF before starting (but not driving) the engine. The engine management light came on and has stayed on through a number of on/off cycles and a 15 min drive.
Only really posting this as the light is still on (I'll plug the Nanocom in tomorrow when its light again) and it surprised me slightly as the TD5 probably wouldn't have flagged this at all - in some cases driving with the MAF unplugged is a fault finding exercise!
So I'm hoping its just a far more sensitive engine/ECU set up rather than a pointer to a more serious issue - I'll find out tomorrow when I look at the nanocom no doubt!
In other peoples expereices is this "the way it is"? and would the engine management light go off on its own after more driving or is it a plug in a clear thing?
thanks all for any words of wisdom - or general thoughts Razz
Si
Post #1078786 30th Oct 2025 6:59pm
Martin
Site Admin
Yes the Puma is supposed to report this sort of thing with a MIL, any emissions-affecting fault must illuminate a MIL (Euro 4 and later requirement IIRC).  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1078789 30th Oct 2025 7:12pm
OrangeAlpine
thanks Martin - that makes sense. And I thought the TD5 was picky at times!
Will plug in the nanocom tomorrow and clear that - and see what else is there, I've been putting that off so far Confused
Post #1078793 30th Oct 2025 7:24pm
Ianh
You will likely have some DTC’s that need clearing with your Nanocom.
PS. Does Your K&N filter need oiling ? If so the oil can mist, contaminate the MAF and cause issues.
Post #1078794 30th Oct 2025 7:31pm
OrangeAlpine
Hi Ian - yes I'm sure there are going to be some codes logged that will need clearing, I've been putting it off since buying it!
Unless there is anything really sinister then I'll just clear them all and see what re-occurs over the next few months
Re the K&N - yes it does need oiling post cleaning. Its new out of the box today so should be ok and I'll be sure to let it air dry for a bit post cleaning/oiling when its due a service.
Post #1078801 30th Oct 2025 7:59pm
Ianh
Just remember to record the DTCs before clearing them and get some dedicated MAF cleaning spray to address any issues down the line.
Ps Bell Auto service did a lot of testing and found that a genuine LR paper air filter performs the best.
Post #1078811 30th Oct 2025 9:21pm
OrangeAlpine
Thanks Ian. Noted and will do
Post #1078814 30th Oct 2025 10:11pm
