| M.teague
     | My fuel lines look chaffed where they are at 90° around the chassis rail to the tank, i have had a look at replacing them but the pictures i see online of the 'pump to engine' sets seem to have different connectors to mine, mainly they seem to have only 2 connectors pictured of the type that connect to the filter head whereas i have two on either side, the online pics show the lines coiled up, i feel i may be missing something here,
The part number i have used to search is WJP500090,
 I have also considered replacing the pipes with high pressure fuel injection hose which can operate safely to 20 bar, this would enable larger radii around the corners, the original is very tight, perhaps too tight for older hardened lines,
 Any advice would be very much appreciated especially regarding whether the WJP500090 set would fit a 2002 hard top defender td5 with four connectors on the filter head or do additional fittings need to be sourced,
 As ever,
 Thanks.
                |  29th Oct 2025 8:55am |  |
                | 34064
                |  29th Oct 2025 2:09pm |  |
