![]() | Home > Puma (Tdci) > TDCi heater controls |
| Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2557
Im afraid it’s either hot or cold, with nothing in the middle.
Re not getting fully cold , if you look at the valve you will likely see it’s not fully closing. To rectify this you can fit a spring on the valve. There is a topic on here with pics to show the spring conversion. https://www.defender2.net/forum/topic78660...lve+spring Edit- added link to spring mod topic Last edited by Ianh on 26th Oct 2025 10:03am. Edited 1 time in total |
| Clemmo Member Since: 03 Aug 2012 Location: Mile Oak Posts: 1334
Yes…it’s hot or cold… no fine tuning.
I have found the Mud Heat Deflector can make you feel “less hot” as it diverts the air blast forward into the footwell rather than onto your leg..but no adjustment. At least with Puma you do get hot…and the Air Con is very good too ( as long as your air con condenser is not in pieces as they often are) Clemmo |
| lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3553
Yes l've got the MUD deflector (fitted by the previous owner) and working A/C
The condenser looks good, it's not lost any vanes. l can't complain about the heat output of the system, it's like a furnace |
| jbcollier Member Since: 29 Apr 2024 Location: Edmonton AB Posts: 286
The range of valve travel and the amount of cable pull do not match. You have to adjust the cable to fully closed in the summer and to fully open in the winter.
The design of heater valve is supposed to be paired with a heater box that blends heated and cooled air to increase the efficiency of the AC system. It doesn't regulate hot coolant flow in relation to cable travel. Bit of pain, true, but actually having HEAT is such a plus, I don't mind at all. You can't fit a volume control type of heater valve as the flow through the heater hoses is important in the rather complicated cooling system. |
| All times are GMT |
