Home > Puma (Tdci) > Headlight level switch
jim4244
England 2013 Defender 90 Puma 2.2 CSW Fuji White
Hi all
Bottom left switch on my 2013 Defender 90 is the headlight level switch. Should this be illuminated when the lights are switched on?
Thanks
Jim
Post #1078239 24th Oct 2025 2:17pm
Martin
Site Admin
The 0-1-2-3 should light up.
There is a bulb (yes a bulb!) soldered to the internal PCB:
https://www.defender2.net/forum/topic90195.html
A lot of them have failed by now.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1078260 24th Oct 2025 5:19pm
jim4244
Thanks Martin 👍
Post #1078277 24th Oct 2025 7:12pm
MatLandy
France 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
Headlamp Leveling Switch - AMR5874 - has been out of stock / unavailable from LR for quite a while and second hand ones from ebay or the likes are more of a it and miss with the bulb often already burned in them. As suggested here https://www.defender2.net/forum/topic86813.html you can solder a replacement bulb. I ended going that route as well, very happy. Just google for "Barthelme 2110124G Micro Filament Lamp Green 12V 0.48W"
/Mat
Post #1078310 25th Oct 2025 9:27am
