![]() | Home > General & Technical (L663) > GAP Diagnostic IIDTool Announcement |
eno Member Since: 15 Apr 2024 Location: Qld Posts: 54 ![]() ![]() |
That must be something recent. I have a 2024 Defender with Meridian sound and it doesn't have any speed control of the volume. Or it's not enabled. But I don't have a GAP tool. And as much as I would like to change the state of a few features i don't want to risk any of the warranty.
Floobydust Member Since: 12 Sep 2025 Location: Massachusetts Posts: 2 ![]() ![]() |
Thank you for your comments. I rented at 2024 for a week (the same spec as mine) and it too had this disease, although the adjustment curve was less aggressive than in my 2025.
As for warranty, the changes I have made are all things you can change normally; I just have it set to retain my preferences. I have no plans to enable features that might cause a warranty issue such as Dynamic Mode, etc. But I would absolutely not care about the warranty if I could rid my audio system of this pestilence. I am hoping that one can enable a infotainment menu like the Range Rover or change a Mulitcan setting to kill the speed signal to the infotainment system. But I don't want to try things randomly as they can lead to real trouble. The kind you can't recover from. |
DiscoDuck Member Since: 04 Oct 2025 Location: North America Posts: 2 ![]() ![]() |
Happy Saturday!
Could someone with a (preferably 2021) North American spec P400 (non plug-in) please upload their CCF? I'm trying to compare engine configurations to unlock. Cheers! |
Norland, I'm a fellow D5 owner, want to compare CCF activation notes? |
Bobbobbobbob Member Since: 04 Jul 2023 Location: Brum Posts: 27 ![]() ![]() |
Saw an old post about this in the thread but couldn't see an answer. Does anyone know a setting so that the rear lights are on all the time with DRL? Looking at older models there used to be a Scandinavian setup
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 473 ![]() ![]() |
Rear lights on - by my knowlegde not solved yet.
https://www.defender2.net/forum/topic77970.html No Mud flaps for my 90.! ----------------------------------------- P300S MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
Huwcil Member Since: 08 Oct 2025 Location: Ceredigion, Wales Posts: 16 ![]() ![]() |
Maybe just switch the sidelights on by turning the switch one notch towards you. The front U shaped DRL’s will be dimmed a bit but still perfectly effective. It would need to be done every time you wanted the rear sidelights on, which would annoy me. |
That doesn't work for long, retains very quick to only DRL's. No Mud flaps for my 90.!
Thanks anyway, was just looking for a way they would be permanently on while driving without me having to do something every time. I'm sure there is a way. I'll keep looking.
rkrutzen Member Since: 15 Oct 2025 Location: Den Haag (NL) Posts: 2 ![]() ![]() |
hello,
I have a 2023 Defender P400e (PHEV) and just got an IID Gap Tool G4. Now I want to make some CCF changes. My question is: The car automatically turns off the ignition after a couple of minutes. Is there a risk it switches off while performing a CCF update? How do I prevent auto switch off while updating? |
stevemfr Member Since: 18 Sep 2022 Location: Strasbpurg Posts: 166 ![]() ![]() |
@rkrutzen
No. Once you've gone through 'Apply Changes' and confirmed all queries the IIDTool communicates with the vehicle and stops all unwanted activities. The vehicle will generally turn off and restart during the CCF programming procedure, but this is nothing to worry about. The IIDTool checks voltage and will not allow CCF programming when the charge level of the battery is no sufficient, but we can only test the voltage which indicates a current state of charge. If the battery is older, you can theoretically have a good momentary state of charge where the battery quickly collapses under load. This is why we recommend a battery maintainer be connected to the vehicle. (But in all honesty, a good battery maintainer is several hundred $€GBP and puts out 25A+. Just make sure your battery is not on its last legs and don't play with the IIDTool without the motor running (OUTDOORS!!! Don't ask why I think it's necessary to mention) for a long period of time (again, don't ask). If you've just driven your Defender and the battery is in good shape, everything will be fine) ![]() ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s, 2 FL1s and a L663 on the way |
Thanks for your detailed response.
I think battery drainage is less of an issue with the PHEV because the battery is charged from the EV battery. |
