![]() | Home > Puma (Tdci) > Grease nipple for Defender Pedal box |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 21012 ![]() ![]() |
They are the same size as those that are on the Puma UJ’s.
Which on a 2 piece fitting this is the smaller one in the picture here: https://www.ebay.co.uk/itm/376437028538?ms...73b58c6ce4 Unfortunately, I don’t have one at hand to measure for you. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18017 ![]() ![]() ![]() |
Have a look at my post one up from the bottom here: https://www.defender2.net/forum/post781671.html
There is some debate whether they are the same as the prop shaft, although on balance it is most likely, in which case they are 1/4" UNF. Also be aware that not all Puma shafts are drilled for a nipple (though most seem to be). |
mifa Member Since: 16 Dec 2022 Location: Denmark Posts: 18 ![]() ![]() |
Thanks!
I got the two original propshafts in store because they were replaced with Gwyn Lewis propshafts. I will see 1) if the shaft are actually drilled and 2) see if it will fit and measure it if others want to have a go not breaking the bank. Michael |
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2526 ![]() ![]() |
Definitely a 1/4 inch UNF, not an M6 , I tested both and the 1/4 UNF was the correct fit. |
Ian
Great, I tested and its drilled out all right, then it just to passe the tractor supply to geet a nipple. Michael |
I suspect Yours is left hand drive. This may be an issue as the pivot pin ( if threaded - not all are) is threaded on the right hand side of the pedal box ( as you look at it standing in front of the vehicle) . It’s the same on a left hand drive vehicle which means there is very limited access due to the wing.
See this topic https://www.defender2.net/forum/topic22839-15.html |
