Home > Puma (Tdci) > Grease nipple for Defender Pedal box
mifa
2007 Defender 90 Puma 2.4 PU Tonga Green
Good evening
To get a little less resistance in the clutch I would like to mount a grease nipple on the pedal box. They can be purchased in various online stores, but 20-25 pounds in shipping is just over the top when I don't need a large portion of scrap. Does anyone know the thread size so that it can be purchased at the local tractor dealer?
Michael
Post #1077485 14th Oct 2025 6:31pm
They are the same size as those that are on the Puma UJ’s.
Which on a 2 piece fitting this is the smaller one in the picture here:
https://www.ebay.co.uk/itm/376437028538?ms...73b58c6ce4
Unfortunately, I don’t have one at hand to measure for you. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1077486 14th Oct 2025 6:39pm
Have a look at my post one up from the bottom here: https://www.defender2.net/forum/post781671.html
There is some debate whether they are the same as the prop shaft, although on balance it is most likely, in which case they are 1/4" UNF. Also be aware that not all Puma shafts are drilled for a nipple (though most seem to be).
Post #1077487 14th Oct 2025 6:42pm
mifa
Thanks!
I got the two original propshafts in store because they were replaced with Gwyn Lewis propshafts.
I will see 1) if the shaft are actually drilled and 2) see if it will fit and measure it if others want to have a go not breaking the bank.
Michael
Post #1077496 14th Oct 2025 7:17pm
Ianh
Definitely a 1/4 inch UNF, not an M6 , I tested both and the 1/4 UNF was the correct fit.
Post #1077529 14th Oct 2025 10:14pm
mifa
Ian
Great, I tested and its drilled out all right, then it just to passe the tractor supply to geet a nipple.
Michael
Post #1077543 15th Oct 2025 5:51am
