![]() | Home > Maintenance & Modifications > Discovery 2 brakes on a defender |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1862 ![]() ![]() ![]() |
Anythings possible and I believe someone on here has done it for front and rear axles, but they're a different track width and its going to be a shed load of work!
HTH Keith |
T3DDY14 Member Since: 23 Jul 2020 Location: Kent Posts: 48 ![]() ![]() ![]() |
Shed load of work is fine, i was thinking of keeping the orignal calipers and adding a second set of carriers (td5 disco ones) by bolting or welding a bracket on and using the other calipers as just a handbrake.
If you have any other suggestions for a hand brake instead im up for it as it wont be on the road for short while as i need to make custom props and sort wiring out |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 1105 ![]() ![]() ![]() |
I might be suggesting something completely wrong here - but what about the disc brake handbrake conversion? 2017 5.0 V8 Supercharged RRS SVR
2008 2.4 110 Utility Station Wagon XS. |
Did think about it but my transfer box wouldnt allow it would need to be axle or caliper ones
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18024 ![]() ![]() ![]() |
Since the Disco 2 handbrake is, like the classic Defender, on the transfer box not the rear hubs, I don't see what you're hoping to achieve.
Use disco two rear brake calipers in tandem with the originals, as ive found the 2007 chyrsler grand voyager had the same caliper as the disco 2 but it also has a mechanical handbrake built into it Defender 110 300tdi hard top
So your plan is to use two Chrysler calipers, not two Disco2 calipers?
Indeed or put a electronic brake caliper instead just using the td5 carriers unless there is a better solution? Defender 110 300tdi hard top
34064 Member Since: 12 Dec 2023 Location: South Central Posts: 233 ![]() ![]() ![]() |
Design development engineering do a Electronic handbrake caliper 110 Td5 Ex Utilities slowly converting into a pop top camper one day
Build thread:https://www.defender2.net/forum/post1024784.html#1024784 |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8474 ![]() ![]() ![]() |
Disc brake setup diff end of prop
Line locks Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
