Home > Td5 > Exhausted
Evil Elsie
United Kingdom 2002 Defender 110 Td5 HT Alpine White
Exhausted
Hey folks,
Currently got the exhaust manifold sitting on my bench. It's not warped but has all of the webs intact. Before I refit it, is it worth running a hacksaw down the webs...??
Cheers, Dave. 2002 Land Rover 110 Td5 Utility
1980 Yamaha RD 350LC
1976 Yamaha RD 400C
Post #1077476 14th Oct 2025 4:18pm
I'd say that it is worth dewebbing but there's more to it than you suggest if you want to to a good job. Ideally you will remove the entirety of each web and smooth the manifold to remove any stress-raisers, so the when you finish it looks as though there never was a web. You will need more than a hacksaw for this.
If, as I infer from your post, you simply cut a slot in the web you greatly increase the risk of the manifold cracking.
Post #1077478 14th Oct 2025 5:40pm
Evil Elsie
Thank you very much - a couple of quick hacksaw cuts was exactly what I was thinking of...
You've saved me a great deal of trouble. Now, do you know anything about removing snapped drills from exhaust manifolds...πŸ˜„
'cos that's what I've just done, trying to drill out a sheared bolt on the EGR blank....
It's been one of those days....😒😒😒😁 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #1077482 14th Oct 2025 6:09pm
Mdm
as above some folk say leave well alone and some say slot with a big grinding disc.
we tend to find total removal is best option and then a coat of heat resistant paint .
for broken drill bit removal. a small hole saw can work.
as can a decent set of extractors, all depends how much you can grab onto
Post #1077489 14th Oct 2025 6:55pm
landy andy
I go for total removal.
Post #1077493 14th Oct 2025 7:02pm
Evil Elsie
Thanks Gents - appreciated πŸ‘
I'm going to leave it alone (apart from the bloody drill bit🀬) - it's nearly 24 years old and covered 179k miles - it doesn't need my ham-fisted attempts to 'improve' it... 😁😁
Cheers, Dave 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #1077516 14th Oct 2025 9:16pm
