Home > Td5 > Vehicle Not Starting
Page 2 of 2 <12
TexasRover
Maybe go a bit further with the easy start and remove the EGR and spray it straight into the intake manifold to eliminate anything turbo, intercooler or EGR related
Post #1077371 13th Oct 2025 6:33am
lightning
When the vehicle initially broke down, the O/P said he found the air filter "soaked with water". l would wonder how this came about, and whether it has any bearing on the continued issues with the vehicle.
l don't know how the air filter could get soaked with water in normal operation. How could this have happened?
Post #1077375 13th Oct 2025 8:16am
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
Ah, the air filter soaked with water! This also happened to a friend with a Defender TD5.
Basically, he had a leak in the raised air intake, and one day, in heavy rain, water was sucked in and reached the paper air filter, which disintegrated and clogged the air intake.
Do you have a high-mounted air intake? “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #1077376 13th Oct 2025 9:06am
sgeobeorge27
United Kingdom 2000 Defender 90 Td5 HT Aintree Green
Yes i got a raised air inta
Post #1077378 13th Oct 2025 9:36am
landy andy
I question if the engine has been setup with the timing being 180 degrees out
Post #1077401 13th Oct 2025 2:14pm
lightning
sgeobeorge27 wrote:
Yes i got a raised air intake
That will explain the water then.
Post #1077415 13th Oct 2025 6:41pm
landy andy
Thinking.
Even if the timing was 180 degrees out it should still try on accelerant.
I think Shocked
Post #1077418 13th Oct 2025 7:43pm
Not necessarily. A good RAI properly fitted is far less likely to admit water that the standard factory set-up. A cheap RAI, especially one that uses the factory plastic between the wing and filter is.quite likely to, especially if someone has tamper with the rather feeble centrifugal water separators.
I'm pleased to say my RAI has never yet admitted water, the centrifugal precleaner makes sure of that, in fact it's so effective even the air filter element remains clean for years.
Post #1077423 13th Oct 2025 8:36pm
Page 2 of 2 <12
