![]() | Home > Puma (Tdci) > Gear change noises ! |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18009 ![]() ![]() ![]() |
By clang I mean, I suppose, thud. Make sure the pedal is fully down.
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3483 ![]() ![]() |
Yeah, now l've cut away the corner of the heavy duty floor mat, l can feel the pedal hitting the end stop.
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3638 ![]() ![]() ![]() |
On later vehicles, the clutch pedal box has a bolt to limit the down movement of the pedal. Thats the thud that you should hear. Only very early vehicles had the foot well as a limit.
As for master cylinders, I had what supposedly been a highly regarded brand (with its associated price) fail in just 8 months. When I opened it up, I found a burr along the top of the piston (just beneath the seal) that gouged the bore beyond a possible rebuild repair. It was always hard for me to get more than 2 years - locally need to use the clutch A LOT until I modified the piston to expand the seals a bit more. It made a massive difference. Not done to the Puma yet, but on my old 90 I am using dot5, not to be mistaken with dot5.1, which is silicone based. As it will eventually leak, at least I do not have a mess to the paintwork. Dot4 is highly corrosive. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
