Home > Puma (Tdci) > Gear change noises !
Page 2 of 3 <123>
lightning
lt's only if l don't get the clutch and engine RPM right.
l am actually getting better at it. First gear is best avoided unless starting on a hill as you almost immediately need to change to second anyway. And then you lose the momentum you've gained, waiting for the engine RPM to drop so you can engage second without crunching.
Post #1077270 11th Oct 2025 10:00am
Double declutch first to second.
Post #1077275 11th Oct 2025 11:12am
Johan_B
Sweden 2007 Defender 110 Puma 2.4 CSW Tonga Green
Blackwolf must have a faster left foot than me, or better hand-foot coordination, to manage a double clutch before becoming stationary again. I’m not saying it can’t be done, just that I’m not there.
Lightning: I’ve started to pay closer attention to my gearshift since this thread started. As I wrote in an other thread, I’ve had a lot of clonking when shifting but have now reached a point where she runs like a ’normal’ car. I too tried different strategies to meet the clutch with a light touch on the accelerator, to match the rpm. Sometimes it worked, sometimes it was much worse.
Now, with new DMs, new bushes and new oil, I don’t touch the accelerator until my left foot is off the clutch. No clunking no jerking. Smooth! And no upshifting below 2500 rpm.
What is it like if you cycle between drive and coasting on a flat road? I had the feeling that there was tremendous amount of play in the driveline and that the rear axle came kicking me in the back upon coasting. Upper link bushes made the biggest difference. Now I almost don’t feel any play and cycling between driving/coasting doesn’t produce any jerkiness or clonking.
I can’t say if you have the same problems as I had, just that once you find yours you’ll be able to shift without problem, even if it doesn’t seem like that right now.
Post #1077295 11th Oct 2025 6:50pm
It possibly helps that I've been driving vehicles with no synchromesh fairly regularly for getting on for 50 years, so double declutching both up and down the box is second nature. With the Puma's superbly low first gear, a clutch brake might have helped but it would baffle 21st century drivers! Very Happy
If you want a real gear change challenge try the (non-synchro) gate change on an early Scammell or similar.
Post #1077300 11th Oct 2025 7:36pm
lightning
Driving along and going on/off the gas there's little if any discernible play in the transmission, only the slight delay while the engine kicks back in when you press the gas pedal.
l'll try not touching the gas pedal until my foot is off the clutch. I can't honestly say whether or not l've done this, until l drive it tomorrow.
Post #1077346 12th Oct 2025 6:07pm
Ianh
This topic on the subject is worth a read https://www.defender2.net/forum/topic32669.html In particular the post from Pete at Bell Auto Services on page 2.
Post #1077353 12th Oct 2025 7:20pm
I would personally change the oil, but also check what Cragster mentions, but it depends on what had attention most recently.
How is the clutch fluid looking too? It’s Hydroscopic (as is brake fluid) which is the same DOT4.
So could have taken on some water, and or seals broken down and blackened the fluid.
Brake and clutch fluid should be changed every 2 years or at each service.
Many garages don’t, if you just get servicing done for you, unless you ask especially for it to be done as well as the service. ____\We|Will|Win/___
____/🇬🇧🇺🇸\____
_//*⛽️🛢️⚙️🧰*\\_
Post #1077359 12th Oct 2025 8:24pm
o4dn
France 2009 Defender 90 Puma 2.4 SW Alaska White
FWIW I find really difficult to double declutch with the Puma - I always do it with the S3 with success, but the clutch on the Puma makes that much harder, I reckon... “A Land Rover immobilized is a moral defeat for the driver and bad publicity for the vehicle, […] it's up to you to do justice to your Land Rover!” - Land Rover Driving Technique.
2009 2.4 Puma Defender 90 SW
1979 Land Rover Series 3 88"
Post #1077360 12th Oct 2025 8:31pm
revd
blackwolf wrote:
Does the clutch exhibit the well-known 'death rattle'?
When working properly and with a good driveline and clutch, the MT82 is a good gearbox and should be a pleasure to drive - certainly it should be a better driving experience than the awful clunky and baulky R380 of old.
I sold my Td5 90 with 200k miles - the original awful clunky and baulky R380 is still giving good service to the new owner
I agree it is a slow box though
Post #1077364 12th Oct 2025 9:27pm
HardCharger
What seals break down and blacken the clutch fluid? It seems to be a persistent problem for me. Also, my master cylinder has a slow leak... again Big Cry I've tried almost all brands of master cylinder except the blue box surprise. They all leak into the driver side floor (LHD) eventually. Am I doing something wrong?
I was told that replacement is better than repair kit. No Better Friend, No Worse Enemy
Post #1077369 13th Oct 2025 2:04am
lightning
l've been driving the Defender today and realised l was not pushing the clutch pedal
right down to the floor.
Having made sure the pedal is fully depressed before changing gear, it's a lot better and not one complaint from the transmission at all today.
Post #1077387 13th Oct 2025 11:22am
Yup, that'll do it! Very Happy
Make sure that there is a definite clang as the pedal bottoms out, I have noticed a lot of drivers become very lazy with the pedal and don't press a clutch all the way down.
Post #1077395 13th Oct 2025 12:22pm
lightning
"l would personally change the oil, but also check what Cragster mentions, but it depends on what had attention most recently.
So could have taken on some water, and or seals broken down and blackened the fluid."
lt's good advice
l am going to do all this ASAP. l've got the pump (to fill the transmission) on the way, together with a T50 Torx bit.
Post #1077397 13th Oct 2025 12:53pm
lightning
"Make sure that there is a definite clang as the pedal bottoms out, I have noticed a lot of drivers become very lazy with the pedal and don't press a clutch all the way down "
There was no clang. l've had a look and the substantial floor mat is preventing the pedal from going right to the end stop.
Can't be helping matters lol.
Post #1077398 13th Oct 2025 12:56pm
jbcollier
Canada 2009 Defender 110 Puma 2.4 SW Alpine White
"They all leak into the driver side floor (LHD) eventually."
Define eventually. Everything wears and leaks "eventually". I would not find it surprising if I had to replace the clutch master every four to five years in regular use. The clutch is used constantly and always to its full travel -- unlike a brake master which doesn't really move that much.
Every year? That would strike me as excessive. Unless it is used commercially, driven most days, and all day long, then I would hope for maybe every two years?
If there is no visible bore wear, you can just fit a kit.
Post #1077402 13th Oct 2025 2:35pm
Page 2 of 3 <123>
