Home > Modifications & Maintenance (L663) > Expedition Rack Refurb
testpilottimmy
I'm considering buying a second hand expedition rack for my 110. Has anyone disassembled one to refurbish one? If I do find one, I'm considering stripping it down at the time of collection and putting it in the car in bits, rather than installing it on the roof, only to remove it again to refurb. What tools would i require for the tear down? I would expect to go with a number of hex bits, torx and security torx and an impact driver, anything else needed?
Post #1076795 3rd Oct 2025 11:53am
LR Nuts
not sure this helps ?
I spotted this earlier this year.
Good Luck
Post #1076804 3rd Oct 2025 2:58pm
testpilottimmy
The ultimate in virtual racks there.
Post #1076807 3rd Oct 2025 3:40pm
testpilottimmy
Answering my own question, the rack can be broken down into component parts with a Torx T30 security bit and an 8mm.
Strip down started, clean up and paint to come.
Post #1077251 10th Oct 2025 6:38pm
LR Nuts
Yes ! ............. it has become a 'thing' Rolling with laughter Rolling with laughter
Post #1077274 11th Oct 2025 11:36am
testpilottimmy
Indeed it has
Post #1077297 11th Oct 2025 8:21pm
testpilottimmy
Well, many things at the moment! On close inspection, there is quite a lot of oxidation bubbling under the coating on the cast parts, I’m looking at quotes for strip and re coat.
Post #1077298 11th Oct 2025 8:21pm
Crazymind
That’s a tricky one. If it has been anodised from factory you need to to give it a bath of sodium hydroxide. Once you se the colour coming off brush it off. Rinse with cold water and neutralise with vinegar or mild acid.
Get it anodised again.
For the metal parts, sure you can fix it yourself with a bit of patience…
Post #1077318 12th Oct 2025 8:21am
testpilottimmy
I’m not sure it has been anodised. The finish is textured, I assume powder coated, as it does flake off around the oxidisation. The long parts appear to be extruded aluminium and the corners and mounting brackets look to be cast aluminium if it makes any difference.
Post #1077320 12th Oct 2025 9:11am
