![]() | Home > General & Technical (L663) > P400e coolant smell and EV mode |
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 137 ![]() ![]() |
You could have a leaking auxiliary radiator - a rock hit my aux radiator and caused a pinhole leak. It always smelled like coolant, but I never got a low coolant warning, nor did I notice the expansion tank being low.
It could also be the O-ring on the coolant line that feeds the turbocharger. That is a common fault on the gas Ingenium engines. 𝟐𝟎𝟐𝟏 𝐃𝐞𝐟𝐞𝐧𝐝𝐞𝐫 𝟏𝟏𝟎 𝐒 𝐏𝟑𝟎𝟎 (Pangea Green over Acorn/Lunar) 𝟐𝟎𝟐𝟑 𝐏𝐨𝐫𝐬𝐜𝐡𝐞 𝐌𝐚𝐜𝐚𝐧 𝐒 (Dolomite Silver over Black/Bordeaux Red) 𝟐𝟎𝟏𝟕 𝐃𝐢𝐬𝐜𝐨𝐯𝐞𝐫𝐲 𝐇𝐒𝐄 𝐋𝐮𝐱𝐮𝐫𝐲 𝐒𝐢𝟔 (Aintree Green over Vintage Tan/Ebony) - Gone 𝟐𝟎𝟏𝟏 𝐋𝐑𝟒 𝐇𝐒𝐄 𝟓.𝟎 (Ipanema Sand over Almond/Arabica) - Gone |
alex68 Member Since: 07 Aug 2025 Location: Steyr Posts: 6 ![]() ![]() |
About the coolant smell: the coolant should contain a fluorescent substance, therefore by using an UV-light, a potential leak should be easy to find. Only if it's inside the engine then you would not see it, only in the oil.
About the switching from Hybrid to EV-only mode, I noticed too (having an P300e) that it takes some time. My conclusion was that it has todo with the ICE-temperature and state (it tries to protect it, f.e. the turbine). Question from my side: how do you see how many km the ICE was active? THX 25.5MY 110 P300e Carpathian grey |
GBstu Member Since: 07 Nov 2024 Location: Lyon Posts: 6 ![]() ![]() ![]() |
Good question about the ICE vs EV miles covered. I thought I saw the data on the LR app, I just took another look and culdnt find it in the new app. You can download all your journeys from the app to a CSV file, the EV distance is recorded for each trip.
macduff Member Since: 04 Nov 2012 Location: NE Posts: 120 ![]() ![]() |
Your EV heater could faulty regarding the delay swapping to ev mode. Mine was reluctant to start off in ev mode & when in cooler ambient temps (below 10 degC). It went to have the issue diagnosed & EV heater was replaced. It now starts in ev mode & stays in EV except where throttle demand kicks engine in. It took a few days for it to settle following the swap as i think they did a software update too. 2023 110 P400e
