Home > General & Technical (L663) > Interval between DPF regeneration
Lollo27
Italy
New to the forum, i own a 2022 d250, I notice the interval between the DPG regenerations has reduced lately.
I don’t know if it’s connected but recently the dealer has changed the all the injection system as it caused a fault.
Thank you
Post #1076853 4th Oct 2025 10:11am
lightning
ln local driving my D250 initiates a regeneration approximately every 100 miles. When it happens l try not to turn off the engine until it's finished, but it's not always possible.
ln that case the vehicle will try to do another regeneration, often the next time the engine is started.
Post #1076855 4th Oct 2025 10:37am
Lollo27
Italy
Oh, it’s even less than mine. I tho in mines does it approximately every 250/400km, depending on diving types. Yes when I notice high idle rpm or higher than zero consumption when the gas pedal is not pressed I know it’s regenerating so I try to let it finish.
Post #1076857 4th Oct 2025 11:29am
lightning
Yours sounds fine, it depends on the type of driving that you do.
When on longer journeys mine will regenerate every 3-500 miles although it's not always possible to detect when it's happening.
Post #1076871 4th Oct 2025 5:02pm
Bigmeg1979
Is there any lights that come on the dash when a regeneration is happening?
Post #1076896 5th Oct 2025 7:48am
ruben
Spain
I wish it were like that!! Defender 110 SE I6 D250 23MY
ExDiscovery 3 TDV6 SE
Post #1076905 5th Oct 2025 9:03am
lightning
There's no lights on the dashboard to tell you.
The only real clues are, the idle speed is a bit higher, start/stop won't work, and the fuel consumption drops very quickly.
However if you've not recently reset the average fuel consumption you won't notice the change.
lf you stop the engine before the regeneration has finished, it will try again. Eventually you'll get a warning light if enough of them fail. But it's never happened with mine.
Post #1076906 5th Oct 2025 10:38am
