![]() | Home > Puma (Tdci) > Doors unlocking and setting off alarm |
| landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 6060
Sticky grease in drivers door lock system or a new central locking actuator in drivers door would be my thoughts.
| jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8494
The lock or the mech behind it is not thrown far enough so solenoid arm doesn't extend all the way. It tries to for a set period then retracts.this then usually results in the horn sounding twice. I've not had the alarm go before with these symptoms.
You get the same when door locks freeze. Investigate door mech on both front doors. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
| irishhawk11 Member Since: 07 Mar 2022 Location: In the Pub crying due to defender issues Posts: 36
I had the same problem, and this is what solved it.
My door panel was somewhat not attached fully, which prevented the plastic locking part at the top of the door not to slide properly. What helped was to make sure that all clips were in place and that the panel was not dangling around. Additionally, when I took the panel off to check all clips and co. I greased all mechanical parts with WD-40. I also put some silicon on the plastic locking part, but not too much. And what finally helped was to lock the door with the key a few times. Since doing these three steps, I never had an issue again, plus after greasing everything, made the window go up far smoother. Hope it helps, Regards Ben |
| markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2708
For me (TD5), the yellow wire running through the rubber trucking between the door and the bulkhead had broken.
I just gently pulled on the wires until I found the broken one then made the repair, no need to buy a replacement loom. |
good point, you could just have a broken supply line to a solenoid. so its not locking the door but in my experience it just locks the other door(s) and does nothing else leaving you with one unlocked door. Cheers
| Chugaboom Member Since: 02 Mar 2022 Location: Sussex Posts: 35
For me it was the bonnet switch, just bent it up by a few mm and the switch fully depressed again when bonnet closed end of problem. You can just open a door one at a time and try locking while you push in the door switches in the door frames one at a time to see if one of these is the issue.
| ct1071 Member Since: 26 Dec 2022 Location: Hampshire Posts: 3
Thanks for all the ideas so far folks.
So after a degree of fiddling (and having the car lock itself with the keys inside |
Quite similar to my failure as stated before - a whole lot of WD40 helped.
So the issue turned out to be the actuator - replaced it and the issue is gone !
| All times are GMT |
